Old 11-16-2003, 02:36 AM
usi_mach usi_mach is offline
Vtec
what's up guys, i just bought a 1995 Honda Civic EX w/ VTEC,
i just wanted to know when it kicked in?, and at what gear?
Old 11-16-2003, 02:38 AM
Re: Vtec
thanks
Old 11-16-2003, 11:06 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Vtec
vtec kicks in at 5500 rpm's in any gear.
Check out my car here My 91 Hatch
Old 11-16-2003, 06:32 PM
sorry, my car is a SI, not a EX, does that make any difference?
Old 11-16-2003, 06:49 PM
JPetey04 JPetey04 is offline
Re: Vtec
yes it makes a difference, you have a totally different engine, instead of the SOHC you have the DOHC Vtec, and you also get 160hp, so your damn lucky,and i do wish i had your engine, i just have the EX, but i thought the vtec kicked in at 4500, thats what the honda dealer told me
Old 11-16-2003, 07:24 PM
Re: Vtec
In 95 there was no DOHC Vtec Si as far as I know 92-95 Ex/Si had the D16z6 125hp SOHC. In 96-00 Ex had the D16y8 127hp, and the Si had the 160hp DOHC B16. If i'm wrong on that i'm sure someone will say so, but to the best of my knowledge that is correct. Also unless your ECU was chiped to have the Vtec kick in at 4500 it should engage at 5500 from the factory.
Old 11-16-2003, 09:40 PM
Re: Vtec
dumped91hatch, your right there was no DOHC VTEC Si, but i'm from Canada, and the only 1.6L, 2Dr. coupe 125HP, was offered in the Si, i'll give you guys the web site, http://www.vmrcanada.com/value_menus...s/95hociic.htm just copy and past it, plus i also went to the canadiantire near my house, and i was looking for a cold air intake and they guys asked me if its' a 2dr. or 4 dr. and what size engine i told him, and shit like that......PLUS, HOW WOULD I KNOW 100% ON HOW BIG MY ENGINE IS......WERE WOULD I LOOK??????
Old 11-16-2003, 11:02 PM
Re: Re: Vtec
Read that site more carefully it says:
1995 Honda Civic FWD/1.5L-I4 (70hp)
Wholesale
Retail
CX 2dr Hbk 4950
6800
DX 2dr Cpe 5225
7125
EX (1.6L-125hp) 4dr Sdn 6025
7900
LX 4dr Sdn 5375
7250
Si (1.6L-125hp/5sp) 2dr Cpe 6100
8000
Add:
ABS brakes 175 175
Alloy wheels 50 50
Cassette 25 25
SE (LX) 225 225
Deduct:
No air cond 400 400
Manual trans (LX,EX) 300 300
The 2 in bold are essentially the same car with different trim levels and minor things. You said yours is a Si so it is the 1.6L 125hp D16Z6.
If you want more info for aftermarket stuff just look around use the trim model (Si) and D16z6, you could also use SOHC Vtec to search by. Also try D-series.org, they have all sorts of info. To find out what motor you have (looking from your front bumper into the engine compartment) it should say on the motor to the right of the tranny. It will be stamped D16z6 with some #'s under it. here is a pic of what the casting stamp should say except mine saysD15b. It's prety much the same as yours but from Japan with 128hp and is SOHC Vtec. Here is a picture of the Full Motor with markings of where to look.
Old 11-17-2003, 12:54 AM
Re: Vtec
well, as soon as i read your message, it was 2am, i went outside with a flash light and looked for it, luckely i found it, it was covered with heavy greese and some other stuff, anyways, i have a D16Z6 got to this site and look at the infor for a D16Z6 http://hybrid2.honda-perf.org/tech/engine.html
Old 11-17-2003, 04:15 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
The Canadian Si trim is the US Ex trim. So, as previously started, your canadian Si Coupe has the same motor as a US Ex, D16Z6. It is essentually a US Ex trim coupe. The US 92-95 Si hatchback also shared the same motor as the Canadian Si and the US Ex.
Also, the exact cc of the motor are 1590.43cc. Also, since it wasn't listed, the rod/stroke ratio is 1.52, the bore is 75, and the stoke is 90. The head is 34.6cc.
I also noticed some mistakes on that site. The 90-91 and 92-93 Integra GS engines were called the B18A1. The site incorrectly called 90-91 GS engine B18B and 92-93 GS engine B18B1. These are both the B18A1. The B18B1 was found in the 94+ LS/RS/GS Integra.
Old 11-17-2003, 01:58 PM
Re: Vtec
thanks,
Old 11-17-2003, 03:01 PM
Re: Vtec
No problem
Old 11-17-2003, 08:56 PM
Honda God
Re: Re: Vtec
thanks,
Your Welcome
Old 11-18-2003, 08:28 PM
hey guys, thanks for all your help, one other thing, is it just me that i hate driving my STICK SHIFT because it's my 4th day driving or is everyone like that for the first couple of month, because ever time i have to go somewhere i'm like "o no, i have to drive a 5speed", i'm just asking you guys cause you seem to know alot, but i asked a couple of my friends, they said i will love it with a couple of months?
!PLEASE REPLY!
!THANK YOU!
Old 11-19-2003, 03:13 AM
Honda God
Re: Vtec
!PLEASE REPLY!
!THANK YOU!
I would think you'll enjoy it after a few months. It's your first few days driving you said, so your still just getting used to the whole thing. I know when I first learned to drive, I was like, Auto all the way. A stick seemed too much of a hassle. Once you settle down and get used to it, I would think you would enough going through the gears, and the control it gives. If you still can't stand a stick after a while, maybe your just an AT person. I've met a few, but most people love the control of a manual once they get used to it.
