Sticking throttle while driving
I have already read the previous threads about sticking throttles on these trucks... But my problem seems to be a little different from the ones already listed.
My 1999 GMC has a 4.3 and a 5-speed. While driving, if I lift off the throttle it doesn't slow down. It is almost like the cruise control is on (it isn't). It also does not decellerate when I shift. It will stay at whatever rpm I was at before I pressed the clutch in. But, if I come to a stop, it goes right down to idle RPM. Any help would be appreciated! |
Re: Sticking throttle while driving
I know you've read this on all the other posts, but you might want to try cleaning the throttle body, it might have some carbon in it.
Re: Re: Sticking throttle while driving
Definately cleaning the trottle body with a spray choke cleaner and a soft tooth brush should help you out.
Also those engines will slowly return to idle speed between shifts...I believe the calibrations in the PCM hold the IAC valve open while driving to prevent stalls.....normal operation
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Well, I took the throttle body off and cleaned it. It didn't make any difference. My girlfriend drove it yesterday and freaked out cause it kept going after she let off the gas. I don't know why, if there is a problem, the computer doesn't trip the check engine light or something. Is there any way to check the throttle position sensor? How about the speed sensor? I hate to just start replacing things.... Would an OBD scanner tell me anything, and what is a cheap but good one of those? What about a real-time setup? Something I could hook up to a laptop and drive down the road to see what it is doing?
