Old 11-15-2003, 11:39 PM
moshersd40 moshersd40 is offline
More Power
I would like to know with out going thru a lot of money and time what is the most likely thing that I can do to get more power and quicker pickup for my 1999 Suburban. It has the v8 vortec engine, I have never messed with this type of engine. I am most used to the old carb engines that most of us had when we were kids. Modern fuel injected and these vortec style engines just give me a headache. Can you give me some assistance on these questions.
Old 11-24-2003, 08:15 AM
jfmctlaw jfmctlaw is offline
Re: More Power
Talk to your dealer or speed store about performance enhancements. Minor changes will give you minor enhancements. Do you want power as in towing power or do you want pure street acceleration? These are both 'power' enhancements at different places on the torque curve.
You could put on a different exhaust system or change the timing curve with a different distributor. Call your shops. Let us know.
Old 12-16-2003, 08:11 PM
Burban man Burban man is offline
You can try this if you want.
www.motorworksperformance.com
Business Hours EST
Sun Appointment
Mon 9:00a - 6:00p
Tues 9:00a - 6:00p
Wed 9:00a - 6:00p
Thurs 9:00a - 6:00p
Fri 9:00a - 6:00p
Sat Appointment
Motorworks Performance is a Warehouse Dealer
Superchips Micro Tuner Max GM Trucks 1996 - 2003 w/ V8 Engines
Quantity in Basket: none
Code: SC2715
Price: $359.99
Shipping Weight: 2.00 pounds
Quantity:
Superchips Micro Tuner Max for all General Motors Trucks
with V8 engines from 1996 to 2003
Gain up to a 10% increase in Horsepower
Gain up to a 13% increase in torque
THE ONLY TUNER ON THE MARKET TO TUNE THROUGHOUT THE POWERBAND AT BOTH PART AND FULL THROTTLE
Enhanceshift points for automatic transmission
Receive enhanced shift point firmness
Correct your speedometer/odometer for tire size or gear ratio changes
Change your fan turn-on and turn-off
Raise or lower your rev limiter
Remove the speed limiter
Installs in Minutes with no tools!
No Longer Requires the VIN# PRIOR to PURCHASING!
The Micro Tuner MAX is ready to use off the shelf. No need to call in a VIN#. The intelligence is now in the Micro Tuner which reads the the vehicles PCM and saves the stock calibrations. The Micro Tuner then determines what calibrations are in the PCM and from a database, the correct performance replacement calibrations are downloaded to the PCM.
Choose a Superchips product 96-97 GM Vehicles w/ LT1 engine 97-98 GM Vehicles w/ LS1 engine 99-00 GM Vehicles w/ LS1 engine 96-97 GM Trucks 5.0L, 5.7L, 7.4L engine 98-00 GM Trucks 5.7L and 7.4L engine 99-00 GM Trucks 4.8L, 5.3L, 6.0L engine 2001 GM Trucks 4.8L, 5.3L, 6.0L engine 2001 GM Vehicles w/ LS1 engine 2002 GM Truck/SUV w/8.1L 1994-2002 Ford Powerstroke Micro Tuner Max 1996-2002 Ford Micro Tuner Max Trucks/SUV/Van w/ V8 & V10
©2002 Motorworks Performance Webmaster All Rights Reserved
