Old 11-15-2003, 07:43 PM
tnhost tnhost is offline
2004 4.3 V6 Engine Noise
I recently bought a 2004 S10 Crew Cab 4X4 with a 4.3 V6 engine. The engine seems to make a lot of noise when accelerating. Even get a ping when accelerating hard. I have 1500 miles on the engine and have been very easy with it to break it in. I changed oil at around 900 miles. The noise is very annoying. When I had 500 miles on the truck, I took it to the service department and took the service guy for a ride. He said that these trucks seem to be noisy and that it was normal. I tend to disagree. I had a ZR2 offroad extened cab before this ZR5 crew cab package and it perfomed awesome.
Has anyone else encountered issues with noise when accelerating?
Thanks
Old 11-16-2003, 01:52 PM
radianguy's Avatar
radianguy radianguy is offline
What grade fuel are you running.You can try going up to the next octane level and see if that helps.
2004 toyota Tacoma TRD 4x4
2003 Polaris 600 Classic Touring
2003 Yamaha YZF 600R
Old 11-18-2003, 06:57 AM
paulsback paulsback is offline
Re: 2004 4.3 V6 Engine Noise
Yeah when my engine starts to ping like that i usually get a tank of high test the next time i fill up and the pinging goes away.
Old 11-19-2003, 04:01 PM
Stock_S10 Stock_S10 is offline
Send a message via AIM to Stock_S10
it could be just a harmonic noise
Old 12-20-2005, 01:57 PM
BlackZR5's Avatar
BlackZR5 BlackZR5 is offline
Unhappy 2002 4.3 V6 Engine Noise
My truck is the same way, it is a loud roar actually and it mostly is at low speeds.
Old 12-23-2005, 08:30 AM
eti engineer's Avatar
eti engineer eti engineer is offline
Check the double cardan joints on the driveshaft. The ball and socket assemblies cannot be lubricated and mine turned to powder after only 3 years and less than 50,000 miles. I finally gave up on mine and had a driveshaft built from scratch at a local driveline shop. Truck has never been better.
You can also visit a website (JTR = Jags That Run) and they offer a kit you can install to line up the driveline so the U-joints aren't at such bad angles. If your truck is lowered, it makes the problem even worse. Chevy didn't do anyone any favors with their stock driveshafts. I re-built mine a couple of times before I said to hell with it and I can tell you that if you don't have a well-equipped garage, some patience, a lot of muscle and know what the hell you are doing, you don't want to attempt this.
Merry Xmas and a Happy New Year
eti engineer
Old 12-23-2005, 09:34 PM
sector95 sector95 is offline
Is this a rebuilt motor? You say it only had 1500 miles on it. Did you rebuild it or was it aftermarket?
What kind of noise? The fan will make a lot of roar until the fan clutch warms up and allows a little slippage. And as "eti" eluded to, the noise might be coming from somewhere else other than the motor.
A *slight*, occasional engine knock is acceptable; the ignition control computer should sense the knock (thru the engine block knock sensor) and dial back the advance a bit.... the computer tries to give the engine as much advance (within the preprogrammed limits) as possible. An engine designed to run on 87 octane will have it's maximum advance set to operate effectively on this fuel.
The 4.3L is a 90 deg V-6 and as such is inheritantly unbalanced in it's firing. Early versions compensated by using an offset crankshaft and later engines had a balance shaft incorporated into the block. In either case, the engine sounds a bit "coarse" and that is normal. The non-balance shafted engines will tend to be a bit rougher in operation.
mike
