Old 11-15-2003, 07:18 PM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
Question 1999 Eclipse Modifications
Hi, i just got a silver 1999 Eclipse GSX, i just want to know what upgrades i can get to make the car a monster! My budget is 7,000 dollars. Thanks for your help.
Old 11-15-2003, 07:56 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
holy shit...7 grand! where to start, where to start! get injectors, fuel pump, new BOV, FMIC, upper and lower IC pipes, MBC - such as AVC-R and you might want to get a S-AFC...there fun to play with, i would suggest DSMlink...cause with that much money for upgrades you will need to tune it and probably keep track of your datalog (you will need a laptop or a Palm Pilot<cheaper to connect to it). turbo back exhaust, new turbo - i would go towards the 20g or maybe if you want crazy boost the T66 is a nuts turbo (its bigger than some peoples heads!!) but that has a lot of lag, so if you have a good fuel system you could do a 75 shot of nitrous to help the spool up so you can loose the turbo lag, i just got 75 shot ZEX wet kit to help with mine just put it in today and i works great!!! well i know there is a lot more you can do for that kind of money but it is all i can come up with right off the top of my head that i have... i'm sure GSXRacer will be along to add to the list or tell you something different, hope that helps!!!
Old 11-15-2003, 08:02 PM
lasersleeper lasersleeper is offline
Re: 1999 Eclipse Modifications
Afrokid- What part of PA are you in? Have you looked at dsmtuners.com, dsmtalk.com, vfaq.com? Theyll get ya started. I am right outside philly and part of phillydsm. If you are in the area, I build DSM's and I can help you out anyway I can.
Old 11-15-2003, 08:23 PM
Afrokid's Avatar
i live in Allentown [about an 1 to 1 and a half drive to philly] .... thanks for the advice
Old 11-15-2003, 10:22 PM
kjewer1 kjewer1 is offline
AF - Advisor
SBR is in PA
Full turbo back exhaust - 800
DSmlink w/95 ECU - 800
Injectors - 300
Pump - 100
FMIC - 1000 (800-1200)
TDO6H with 20g or 50 trim comp wheel - 1200
ACT 2600 clutch - 380
HKS cams - 600
K&N - 40-90
1g BOV - 40
MAF Translator - 300
4 SPider Center Diff - 500
Thats about 6100 bucks, and more than enough for 11s. I didnt include little things like boost guage, etc. And there is no labor incuded. But this is all of the big stuff right up to built block and built tranny. This will basically max out the 7 bolt block. The next level is a 6 bolt or built 6 bolt block, and larger turbo.
BTW, this is basically a copy of Joe G's mod list on our site, www.posracing.net. That car went 12.0 at 116 with me driving, on a small 16g turbo. If you look at Chads mod list, he dynoed 500 whp. These are typical upgrade paths and results, so use them as a guide. Good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-16-2003, 05:52 PM
Afrokid's Avatar
thanks alot
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
