Old 11-15-2003, 04:44 PM
BigDodge2 BigDodge2 is offline
2002 grand caravan transmission fluid change
Anyone got and specifics or tips on changing the tranny fluid in a 02 auto.
Thanks
BigDodge2
Old 11-15-2003, 10:38 PM
yale329 yale329 is offline
Re: 2002 grand caravan transmission fluid change
I can't be sure, but there should be no adjustments. Just drop the pan, check the magnet in the pan for metal filings which would not be a good sign. Wash the pan install with a new gasket, top up with about four litres to start. Any reason your changing the fluid? I changed mine just for the reason that I prefer synthetic. If thats the reason, take it to a tranmission shop and get it drained completely, For they can flush most all of the oil out of the converter. Otherwise you will only replace around a gallon.
Old 11-16-2003, 12:20 AM
change atf
due maintenance....got 42000miles on it. I am going to use amsoil atf+4 cheaper than mopar fluid.
bigDodge2
Old 11-16-2003, 12:40 AM
I was just curious, Good call.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
