Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-15-2003, 03:18 PM
Marcdu4 Marcdu4 is offline
Fuel Filter Replacement
I have a '97 Toyota Tacoma 4WD....does anybody know of a link or information about replacing the fuel filter?
Old 11-20-2003, 12:43 AM
Areku_x Areku_x is offline
Send a message via AIM to Areku_x Send a message via MSN to Areku_x
Re: Fuel Filter Replacement
Go to www.kragen.com, pick your model, than proceed to Replacement Parts.
Old 12-03-2003, 12:44 AM
suv suv is offline
It's located just inside the framerail on the driver's side. Simple wrench off, wrench on process. One hint: replace it when you're almost out of gas, and you'll have less fuel leak out.
Old 12-12-2003, 07:51 AM
LabradorBoy LabradorBoy is offline
In the engine bay, on the firewall, behind the enigne if it's a 2.7L I4
Next to the driver's side frame rail underneath your truck, if it's a 3.4L V6.
The V6's fuel filter is a breeze to change, the I4's it tougher due to space constraints.
Be sur eto slacken your fuel cap before you start working on either, it will release the pressure in the system and you won't lose as much fuel on you, on the ground, etc.
-Rob
Old 01-06-2004, 01:54 AM
Kuch Kuch is offline
Be Sure not to use a straight wrench. You'll round off the nut with the first turn.
Use a open end hex wrench/fuel line wrench.
