Old 11-15-2003, 02:55 PM
B4VITALY B4VITALY is offline
Question 1995 Tahoe remote programming
Hello, Everyone.
I'm knew to this forum. So please bare with me. I have searched around for the answer to my question as to how do I program my keyless remote to work on my 1995 Tahoe. I have found instruction for a 1996 Tahoe, and tried them (hold down the lock and unlock buttons for 10 seconds or more), but it does not seem to work on my 1995. Can someone please help me.
Thank you.
Old 12-29-2003, 05:28 PM
Bas_GMC Bas_GMC is offline
Re: 1995 Tahoe remote programming
Originally Posted by B4VITALY
Hello, Everyone.
Thank you.
Transmitter Programming Base
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
1. Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
2. Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
3. Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
4. Remove the ground applied to the DLC.
5. Lock and unlock the doors in order to verify the transmitter operation.
6. Activate the rear window release in order to verify the transmitter operation.
Bas
Old 01-10-2004, 03:16 PM
Question Re: Re: 1995 Tahoe remote programming
Hi,
Thank You For Your Response, But I Checked Out The Dlc Under The Dash, And My 1995 Tahoe Only Has 6 Slots (not 8) In Two Rows. The Top Row Only Has The Last 2 Filled.
Is There AnythinG Else I Can Do?
Please Help.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
