Old 11-15-2003, 08:56 AM
Woodster Woodster is offline
bucking from dead stop
Hi All,
I have a 1994 Chev C-1500 with the 4.3L engine and only 23,000 actual miles on it. Most of my driving is around town and short hops. Many times the engine doesn't heat up to operating temp.
My problem, yesterday, was taking off from a dead stop my truck bucks like everything until I reach 20 MPH then it's fine. Starts good and sounds good in neutral, but like I say, under load it bucks like mad until 20. The problem is intermittent, but yesterday, it was exceptionally bad. I had the wires, plugs, rotor and cap replaced along with the 02 sensor not too long ago.
I had my mechanic put it on the diagnostic computer to see if he could find any faults. None. The "check engine" light doesn't come on when my truck is bucking. He's stymied and I afraid to take it out of town.
Any suggestions?
Woodster
Old 11-15-2003, 09:36 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: bucking from dead stop
It sounds like you have developed a misfire condition.
I would have the ignition system tested first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-15-2003, 05:57 PM
oldbluecelica's Avatar
oldbluecelica oldbluecelica is offline
Send a message via AIM to oldbluecelica Send a message via MSN to oldbluecelica Send a message via Yahoo to oldbluecelica
automatic or manuel?
suonds like a dirvetriane issue if it stops at 20. is that when it shifts?
Old 11-16-2003, 04:22 PM
Hi Oldblue,
The bucking stops at 20 M.P.H. and the transmission is a 3 speed automatic with overdrive. At 20, I should be in at least 2nd by then. Strange as it may seem, it doesn't buck in reverse. Drivetrain? Sounds plausable. With my truck in neutral, no bucking. Only when under power and I try to move.
I checked in with my mechanic. He disconected the EGR vacuum hose and told me to run it for a few days to see if anything happens. I haven't tried it out as yet.
Many thanks for your reply,
Woodster
Old 11-18-2003, 12:20 PM
RABarrett RABarrett is offline
I also suspect ignition related problems. Having the engine 'scoped would reveal many things. In today's methods of doing things, the computer is blamed before gathering the facts. Now as in past times, the ignition will cause more than 90% of your problems. It is possible for one of your new parts to have a problem, likely the wires. Ray
Old 11-19-2003, 09:00 AM
Jimmy Eaddy Jimmy Eaddy is offline
Have you replaced the fuel filter? It might not be getting enough fuel.
Old 11-19-2003, 10:09 AM
Re: Re: bucking from dead stop
! I had the same problem with my 95 chev 4.3. I replaced the fuel filter under bed. It fixed mine. Give it a try! Alot less expensive!
