Replacing radio on 2003 Caravan-getting into dash
How do I get the dash apart to replace the radio?
Just above the cup holder/ashtray is a snapped in trim plate. Use either your fingernail or a small flathead and pop it off. Two clips hold it in place are very easily popped off. Behind it are 2 phillips screws. When you take these off your ashtray will be loose so don't be alarmed. Grasp the bottom of the center dash bezel and gently pull back until you pop off the 4 metal clips. There are 2 clips at the sides in the middle and the remaining 2 at the top. Hold the bezel with one hand while you undo the 4 radio screws with a cordless drill. Slide the radio out and use your fingernail to undo the 18-pin radio harness. For the antenna grab the black plastic clip pushed into the back of the radio and give it a good hard pull as these are pretty snug. That's all there is to it. Hope this helps you out.
Tazman, Thanks for taking the time to give detailed instructions. It was easy with your help.
I installed a CD/Tape/AM/FM in wife's van that I had gotten from the local Junk Yard . Much much better sound and she can play CD's now! Thanks again. PS My dad showed me a trick to clean up the radio from the junk yard without damaging it. I used a new paint brush and a little patience... |
