Old 11-14-2003, 07:55 PM
POScar49 POScar49 is offline
coolant leaking
i have to replace my coolant every day because the sh*t keeps leaking out of, i hope, only one hose. i just got the pump replaced, but i havent seen any coolant leaking from that side of the engine so i dont think thats a problem. i found a hose that bubbles coolant out wen the engine gets hot, so im guessing that its that hose. by replacing it u think itll end my problems? or do u think i should check any other stuff?
Old 11-14-2003, 10:41 PM
BullShifter's Avatar
Re: coolant leaking
If the hose is leaking, replace it. Replace both hoses if they haven't been replaced in a while to prevent this problem from happening again. YOu could also have the cooling system pressure tested for other leaks.
Make sure to bleed out all the air after repairing - do this after the engine is warm(fan comes on then off)
