Old 11-14-2003, 05:45 PM
likitea likitea is offline
what is the best sound system?
hey, what is the best sound system that comes with a box, 1 or 2 subs, and an amp, what company makes really good sound systems, what are the best types of boxes to have ur subs in if u listen to rap that has a lot of bass? need help to see if my system will be a good deal, chechout my othere post if u are an expert or u can give some opinions or advice. thanks
Old 11-15-2003, 08:25 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: what is the best sound system?
buy 2 JL 13 W7s port them to about 38hz or so, put enough power up to them with an avionixx amplifier to power both subs to their full excursion, or buy 2 e15a.22 in a dual ported box, tuned it to about 30 hz - 34hz with a Avionixx AXT 1800.2 wired @ 2x2ohms 900 watts to each sub. Also look into http://www.adireaudio.com/mobile_aud...hma_series.htm the 15" subs. 2 of those ported in a 7cubic foot dual port box tuned to 28hz using a Avionixx 1200.2 Amplifier. These all should pump like nuts. But that is just my opinion.http://www.adireaudio.com/Files/ExplorerRoofBrahma.AVI
Old 11-15-2003, 11:16 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
what he said (except I would tune lower, just personal preference....I love the LOW notes)
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-21-2003, 07:45 PM
loismustdie loismustdie is offline
i would also tune lower, but i hope your budget is big as hell, because those systems will run you over 1000$. i would recomend the elemental designs setup or the adire brahma setup, i know those amps are good, but there are other good ones so pick and choose.
the loudest system in there is the adire brahma and amp. which is expensive, but if you get two brahma's you will blow your fuckin' ears off.
