Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-14-2003, 11:51 AM
david1234 david1234 is offline
check engine light on Camshaft sensor
I have a problem with my check engine light. Well i went to the garage and the guy told me the code problem and it was P0342 that mean camshaft sensor. So i buy a new camshaft sensor and i also change my four spark plug (AC DELCO) and after that the check engine light go off and 1 day after the light came back ON and it was the same code P0342camshaft sensor. i need help with that .
Old 11-17-2003, 03:16 PM
RABarrett RABarrett is offline
The ECM looks at the cam sensor and compares those readings with others it gets from the crank, vehicle speed, and various other readings to compare these readings. It may falsely condemn the cam sensor if some reading does not compare between it and another sensor. The ECM cannot distinguish which reading is incorrect; it can only determine a mismatch and guess. I would suspect the air flow sensor, the crank sensor, or tps, the sensors it uses for comparison. Tapping on these may lead to a solution. Ray
Old 11-19-2003, 05:31 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Here is the circuit description.
The camshaft position (CMP) sensor correlates the crankshaft to camshaft position so that the Powertrain Control Module (PCM) can determine which cylinder is ready to be fueled by the injector. The CMP sensor also determines which cylinder is misfiring when a misfire is present. If the PCM receives an intermittent signal from the CMP, then the CMP Resync Counter will increment. When the PCM cannot use the information from the CMP sensor, a DTC is set and the PCM will fuel the engine by using the alternating synchronous double fire (ASDF) method.
But first things first, what year, make, model and engine size is the vehicle in question...although the circuit description is the same for just about all GM cars, there is some important information we need to know to give you good solid ideas on what to look for.
Basically the cam sensors recieves power and ground from the PCM and sends the PCM a signal back...any problems with wire integrity will turn on the SES light as will a faulty PCM
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
