Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 11-14-2003, 10:27 AM
akfx0 akfx0 is offline
pro/con with the FC
arite, i'm planning on purchasing a 1987 rx-7 turbo II. i heard from a friend who says that the FC rotary engine has some problems with it and is difficult to maintain. the one i'm planning on purchasing has the following on it:
-relocated battery to one of the bins in the back
-it has an optima bat
-it has the RB dual pulley on the alternator.
-Infini steering wheel from a jap spec third gen on.
-RB oil cooler hoses
-replaced all of the the coolant hoses.
-intake
-HKS blow off valve
-blitz dual turbo timer
-keyless entry.
-few new o.e.m. parts to replace the old dirty ones
-has 89 tail lights.
i'd appreciate it if you can provide some feedback to how well the FC is (i.e. high maintaince car, problems with the rotary engine, etc.)
as well as and pro's and con's of the car. if you could also give me an estimate of how much this car is worth, that would be greatly appreciated. thank you very much.
Old 11-14-2003, 03:26 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: pro/con with the FC
First off, mileage would be a BIG factor in your pricing. Do you have the mileage of the car?
Second, the rotary is a WONDERFUL motor, and if treated right, will last a long time. Its capable of more "bang for your buck" then most other motors out there. THE PROBLEM IS, it doesnt take well to mistakes. If you start to modify your rotary, you have to do it right.
Most people get a TII, and start cranking up the boost with little regard to fueling, etc.. And rotaries dont like to ping..AT ALL.
If that car is in perfect shape, and mileage is 100k or less, 3000 or so is about what I would pay.
Jarrett
1988 10th AE Edition TII
More mods then you have.
Old 11-17-2003, 12:21 AM
thanks for your reply. yeah its a nice car. but the price got a little too expensive for me. i was looking around and i see alot of FC's out there. i know the rotary engine is different, so what should make sure is in good condition other than the milage?
Old 11-17-2003, 12:41 AM
J-Rat's Avatar
How easy it starts (especially when warm) is a good start. Check ALL electronics, FCs are notorious for bad wiring If the mileage is 150,000 or so, and the motor hasnt been swapped, plan on swapping it, soon. Although the N/As can run to 200,000 plus miles.]
Jarrett
Old 11-17-2003, 04:27 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
once its been running idle for a few minutes hold it at 6k rpms and have someone watch the exhaust gases, if greenish blueish smoke comes out you might wanna check the o-rings and seals and that kinda stuff, they tend to go out
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
