My truck is stalling out while I'm driving it and at stop lights. It has new plugs, wires, and dist-cap. The fuel is pumping fine and there are no fuel injector problems. When it stalls I disconnect then reconnect the wire at the center of the dist-cap and at the other end where it connects and then the truck starts. This wire is new also. Any help on the fix? Thanks!
Re: 1995 GMC 5.7L K1500 stalls out
When it stalls, does it restart or does it spin and not start?
Are you removing and reinstalling the coil wire?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: Re: 1995 GMC 5.7L K1500 stalls out
I have the same truck and had the same problem a few wks ago. It would only restart if I mashed the throttle to the floor. That told me that the TBU was getting too much fuel and by opening the throttle plates I was letting more air into the engine. I first replaced the fuel psi regulator thinking that it failed and it was letting excess fuel by into the TBU. That wasn't it. I then noticed that the (ECT) engine coolant temp sensor connector (2-wire connector with blk/yellow wires at the front of the intake manifold) had broken off causing the ECM (computor) to think that the engine was running cold all the time so it was dumping excess fuel into the TBU. I replaced the sensor and spliced in a new connector and the engine runs great. Hope this helps.
same problem as well as fix
It sounds like a throttle position sensor is starting to go I would test the sensor? |
