Old 11-12-2003, 11:47 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Angry Bad Electrical Conections
Alright my car is finally giving me problems. i think i know what it is. my car is losing power when i try to start it. i will turn my key to the on possition before i crank, everything comes on, dashlights, stereo, turbo timer, as soon as i turn the key to start it looses power completely like i pulled a connection to my battery.but my turbo timer still beebs off. my positive terminal was fairly corroded so i went ahead and cleaned that connection completly. hooked it back up and car started perfectly. later today it went back to loosing power. also i pulled the battery and ran a load test on it and it passed so i know it isnt a shity battery. but i was inspecting the wiring and the rubber coating was cut back farther than the connections and some corrosion had begun creeping down them. is this the main source of my problem??? also how hard is it to rewire all the constant hots running off the battery???(the two wires that run from the + terminal to the fuse block under the hood and of course the main one running to the starter???). and if i need to replace all of them would i be better off to just go ahead and relocate the battery in my hatch since i have to rewire everything??? thanks for the help.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 11-12-2003, 11:56 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yea either that wire is really starting to get corroded or you have a loose connections - thats happend to me and it was my ground wire... i ended up melting it before i knew what it was, so check you ground too! anyway if you do end up moving your battery to the back, i would suggest using 0/1 gauge cause there is gunna be a big difference on how far that power has to be pulled from. plus then with the bigger wire it wont make the alternater work as hard to charge the battery, well good luck with that hope it helps!!!
Old 11-13-2003, 10:13 AM
95_GSX's Avatar
Re: Bad Electrical Conections
Just wanted to bring this back up. thanks for the help.
Got AWD?
'08 Buell 1125R
2000 Golf Bad Electrical Problems talon92 Golf 6 03-13-2005 08:32 PM
bad electrical problem blitzgp Golf 8 01-11-2005 02:10 PM
I need help bad, electrical issues making my hair gray! Wayfarer696 Grand Prix 19 09-03-2004 08:55 AM
bad electrical problem nathan_nap Eclipse 2000+ 1 07-22-2004 12:07 AM
Bad electric problem.... Guten Tag 3 Series 2 08-03-2003 10:23 PM
