Old 11-12-2003, 09:42 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Question Putty Help For My SS!!!
putty help!
the area where the circle is (right at point) i have to put putty. But everytime i sand it, it always breaks apart and falls off. Help..anyone?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-12-2003, 09:53 PM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: Putty Help For My SS!!!
depending on how much needs to be done, id use superglue and baking soda, its kinda a task but it will work: put some superglue in an area, then dust it with baking soda. Sand/file into proportions. Repeat until desired.
Old 11-12-2003, 10:50 PM
BaNe BaNe is offline
lol thats a pretty ghetto drawing you got there.
Name is Luke.
Faster and Faster until the thrill of speed overcomes the fear of death.
CompletelyStock except 17 Enkei RS6, Megan racing Downpipe-3" piping-megan racing muffler. no cat. K&N filter.
Old 11-13-2003, 12:14 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
You should draw the rest of the car, we wouldn't know the difference between the model and your drawing!
...J/K
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 11-13-2003, 12:21 AM
jla's Avatar
jla jla is offline
i dont know if you tried this, but you should scuff up the area that youre using putty on with some agressive sand paper. btw what kind of putty are you using? if its one of those 2 part systems try putting less hardner on it, more hardener tends to make it more brittle
Old 11-13-2003, 12:51 AM
Jonno's Avatar
I wouldn't use too agressive sandpaper, because as I understand it, it is on a corner, and using a sand paper with a real low grit will only create the need for more putty... I would probably give it a light sand with 1000 or higher grit.
I have never used the Baking soda and superglue method, but I hear it works well, hard to sand though.
Old 11-13-2003, 06:04 AM
yeah, im a better drawer through. If CD was working i'd show some of my sketches
Old 11-13-2003, 09:40 AM
asaenz's Avatar
asaenz asaenz is offline
Sketch Guy
Hello,
I posted a response about evercoat in your other thread
http://www.automotiveforums.com/vbul...d.php?t=152581
AutoArtShop.com
Old 11-13-2003, 11:55 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
If that's the gap between the hood and the fender...
use some sheet plastic...
I'd put it on the fender, but, it may be easer to put it on the edge of the hood (making the hood wider). Use plastic thicker than the gap and you can sand it to a perfect fit.
SCCA 7, The lost Z
