Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-12-2003, 08:12 PM
wrm59341 wrm59341 is offline
how do you remove starter on 1999
how do you get access to starter and remove it? It is barely vsible from any angle on the 1999 corolla? Please advise of how it is done.
Old 01-26-2004, 12:33 AM
Big_Lug Big_Lug is offline
Re: how do you remove starter on 1999
Best Option:
1. Remove radiator fan assembly. You will need fans out of the way to remove starter from the top.
2. remove plastic tray from underside car just below radiator/starter. You may need to access the one visible bolt from below.
3. remove air filter assembly. You can only access the 2nd starter mounting bolt from this side. You will need a 14mm socket.
