Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-12-2003, 08:12 PM
onlycool onlycool is offline
96 Nissan MAXIMA EGR valve problem!
if the EGR valve is logged, and i don't fix it, what will be happen? are there anybody know?
Thanks
Old 11-19-2003, 11:20 AM
jmd102 jmd102 is offline
Re: 96 Nissan MAXIMA EGR valve problem!
EGR controls Emissions of NOX and helps to cool combustion temps down when engine is under load mobile only. Failing to repair may cause engine detonation / pre-ignition which if serious enough can cook spark plugs or in extreme cases melt pistons. Chances are though your newer max would or may have a knock sensor. If this is the case, the instant detonation occurs, the knock sensor will retard igntion timing to help correct the problem. This may in turn rob you of some performance. I would get the code diagnosed and repaired! Goodluck.
Old 11-19-2003, 09:23 PM
Ceasars Chariot Ceasars Chariot is offline
im getting this code and mild pinging under mild load. whats the cost of fixing/replacing egr ?
97 Nissan Maxima (NA with USIM) - [email protected] mph
97 Nissan Pulsar SRV VZR (stock) - [email protected] mph
Old 11-23-2003, 11:43 PM
Check vacuum lines etc. going to the valve. It may be a vacuum problem or a control problem. IE: control solenioid, vacuum transducer if equipped. (Check your underhood emissions sticker/vacuum line diagram and trace accordingly to make sure the correct vacuum lines are in place. If so, you got either a bad valve or bad control solenoid. More testing required to isolate.
Gotta good shop manual for your car?? Something you shouldn't be without if you wanna tackle this yourself.
Goodluck!
Mark
