Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-11-2001, 05:31 PM
Smitty90acc's Avatar
Smitty90acc Smitty90acc is offline
Send a message via ICQ to Smitty90acc Send a message via AIM to Smitty90acc
Widest tire on a 15 x 5.5" rim?
I'm looking to do some autoXing next year and I don't want to run on my 17's since they weigh 21 pounds each. I would like to know what is the widest tire size I can fit on my stock rims (15 x 5.5). I was thinking about 215/50/15, but I'm not sure they will fit.
Also, does anyone know how heavy the stock 4th gen Accord EX rims are?
|| Professor of Accordic Physics in the Faculty of Honda, B.H., M.H. ||
Proud Toronto Accord Club Member
Old 12-11-2001, 10:56 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
Hey Smitty,if you look at the tire charts from the manufacturer,they state the narrowest and the widest approved rim width for each of the tire sizes.I'll try and find one or maybe they are listed on their websites.
Old 12-11-2001, 11:08 PM
89ssgti's Avatar
Thumbs up
Just like that.
Old 12-12-2001, 01:36 AM
texan's Avatar
texan texan is offline
Writer Mod
Also, remember that wider is not always better. A tire that just barely fits on the rim is not going to perform as well as it would on a wider rim, the orientation of the sidewall and tire bead to the rim is a very important factor in how the tire behaves. I run 225/45 tires on my stock rims (which come with 205/50's), and though these tires have much more grip than the stockers, I did notice a small decrease in responsiveness at turn-in due to the different seating of sidewall to rim (not as vertical on the bigger tire, it has to stretch in a bit from the tread to seat on the rim).
'03 Corvette Z06
'99 Prelude SH
Old 12-12-2001, 08:28 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Exactly cause the bigger tire on the wrong rim will cause it to balloon in the middle and when autocrossing you will never be able to use the whole tire effectively even playing with air pressures.
185/65x14" 195/55x15" are the correct tires for a Civic so you could go to a 195/60x14" or a 205/50x15" for a little bit bigger contact patch, but anything bigger than that will downgrade your handling.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 12-12-2001, 09:33 AM
This is all very interesting. I guess I should stick to a 205 section tire if I want to use those stock rims. Thanks a lot guys!
Old 12-12-2001, 09:50 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
That is max where you are at now
M.Sanew - AutomotiveArticles.com
