Whats up.. I own A 2000 Grand Prix G.T. and i have a whineing also, but its kinda differant then all of yours.. when the engine is cold it doesnt whine, but after like 5 minutes of driving everytime the rpm's hit 2500, it makes a whineing sound. at first i thought it was coming from the front of the engine, but i was drivin it around today and it sounds like its coming from the back. Could it possibaly be the exaust? iv brought it to the service department at major world chevrolet (where i bought the car) and they checked under the hood at the trany and didnt fine anything. and i brought it to a service place around where i live and they changed the transmiton fluid and checked it out but it is still whining at 2500 rpm's. i realy need some help and i dont know much about cars. this is my 1st car and im 17 years old... if you know anything about this drop a line, and ill have my mechanic look at it.. thanks a lot... Tom.
find the problem
you might try having a friend sit in the car while it's parked and reving it up to 2500 rpm and see if you can find the noise... keep the hood open and see if it's comming from the belt/pully system (on the passenger side of the engine) or somewhere else...notice if it only happens when you are moving or if it happens when the rpms are reach a certain speed.
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer. |
Re: Whineing at around 2500 rpms >> Please help
Allright ill do that tomroro.. the car runs nice and smooth, but uts just that anoying noise. I also wanto to put intake in the car. What do you guys recomend, and should i make shure to have this problem fixed first b4 i do the intake or should i not worry about it?...
intake
for the intake i recomend a k&n filter and maybe a fender wall intake. i don't think it would be a problem to go ahead and put that in before you get the noise taken care of. but if money is an issue you might want to make sure that it's not something you will need to fix soon like a water pump or leaky exaust pipe.
the exaust pipes are leaking.. like drops.(idk if that is normal)..like i said im not that good with cars and stuff but im here to learn. it leaks out of the exhaust pipes and in the groves of the pipes where they connect.. and if that is bad... do i need a whole new exaust system.. or should i bring it to the mechanic and let him look at the exaust.. i just bout the car about a month ago and i have a guarente on it.. its just inconvienient to keep bringin it up there and arranging a ride back... thanks again...
exaust
leaking air? you could replace it but you shouldn't have to...if you take it to an exaust place they should be able to weld it shut where ever it's leaking.
