Old 11-12-2003, 07:47 PM
speedyvision917 speedyvision917 is offline
changing bed
is it possible to remove the long bed on my 85 c-10 and put on a short bed? im pretty sure the truck is a 3/4 ton and its 2wd
All you need in life is your car and your girl...Damn all you really need is your car and a hott ass to sit in it with you... haha have fun in life
Old 11-13-2003, 11:45 PM
dirt49er dirt49er is offline
Re: changing bed
a way to tell if it is a 3/4 ton or a 1/2 ton is but the lugz, a 5 lug is 1/2 ton for 2wd and a six lug is 1/2 ton for 4x4, an eight lug is a 3/4 ton, 2wd or 4wd. and it is kind of a bitch to chang the bed, if it has saddlebag gas tanks the you have to pull those, along with the wiring for the tail lights, etc...
Old 11-14-2003, 01:07 AM
Cam70dude Cam70dude is offline
Re: changing bed
The only way to put the shorter 6.5 bed on a truck made for 8' is to shorten the frame so that you can get the wheels to line up with the wheel wells. You would need to cut the frame somewhere between the cab and rear axle.
Old 11-14-2003, 08:34 PM
Re: changing bed
ok thanks wat i forgot to think about before i posted is the wheel wells, but thanks for the info on wat size it is
Old 11-17-2003, 02:24 AM
Re: shot bed
No problemo. I am sorta in the same situation as you. I have a 1980 3/4 crew cab 4x4 that I am completely re-doing and cant seem to make up my mind what to do about the bed. Sometimes I think it would be cool to put an aluminum flat bed or maybe keep the stock long bed and add dually fender extensions (turn it into a dually), or cut and shorten the frame and add the short bed box and to make it even a harder choice I thought last night about putting the 8' stepside bed on it just to be WAY different.....too many options and minimal brain cells to make a decision with....lol
