Old 11-12-2003, 06:33 PM
trooper1822 trooper1822 is offline
think my motor blew
well in a few days i am going to take my car to get a diegnostics done. my car still wont start. what i need to know is what are some sighns my motor has seized, about how much would it cost to get fixed. the other thing people on this page have told me is that it could be the starter. what are some sighns my starter might have died. as i said before the only thing my car dose when I try to start it is go click. the motor dose not try and turn over. just click lights work, radio works. i really need your help out there. thanks
Old 11-12-2003, 11:10 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
first of all is it a 5 speed, if so put it in neutral, have someone pull you to a hill or some place steep... put it in first and start rolling down the hill with the clutch in, after you start to pick up a little speed let the clutch out, but make sure that the ignition is on and give it a little gas, now when the engine starts to turn over if it starts then you know its your starter, but if it doesnt turn over then you know the motors seized, that would be the cheapest way that i can think of right now, you could pull you front driver side wheel off and take of you timing belt covers and try to spin the crank with a torque wrench or a impact wrench... good luck
Old 11-13-2003, 02:16 AM
kjewer1 kjewer1 is offline
AF - Advisor
I already gave you simple method to check if its seized, takes 2 minutes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
