Old 11-12-2003, 02:08 PM
mikaz mikaz is offline
AMT fast and the furious Supra
I just read about the fast and the furious supra from latest scale auto mag, and it looked quite interesting. Have anybody any experience about that model.
One thing i noticed was that the rims looked pretty bad, but all the other details looked quite good and interesting.
Old 11-12-2003, 02:32 PM
Vric's Avatar
Vric Vric is offline
Re: AMT fast and the furious Supra
use the search option. Lot of comments on this one.. and look on my website i made one quite modified
Old 11-12-2003, 02:39 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
It's a decent kit, here's a review link.
http://www.automotiveforums.com/vbul...6&postcount=10
Old 11-12-2003, 04:55 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
I have built 2 and have no complaints, for an recent AMT kit, its actually pretty good, except the rims suck...and the wing is a bit big for my liking. just my
Old 11-12-2003, 05:11 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
I've built 2 also. The only problem i had was 1: brake rotors dont all aline (my fault; super glue set up too quickly) and the upper A-Arm is too weak, and flexible, causing the spindle to pop out, casung the tie rod to pop out, causing you to get pissed off. lol
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-12-2003, 08:32 PM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
http://www.automotiveforums.com/vbul...d.php?t=150186
heres the link to mine. Same problems as mentioned above except I didnt have any problems with the wheels, but also the body is a bitch to get on. I cut down the tabs in front so the body will fit right and extended the tabs in back to fit the slots.
Scott
Fastest hunk of junk in the Galaxy.....
Old 11-12-2003, 08:48 PM
SonyMobile's Avatar
Re: Re: AMT fast and the furious Supra
I also found this to be a problem, the spindle that holds the front brake rotors and wheels that is supposed to slide into a small hole in the lower A Arm, well it doesnt hold it to well, infact both of mine have a small negative camber (whitch is ok for me) this caused me alot of anger because i could never get the posts to sit in the holes, and it causes the wheels to turn at different angles when you try to turn them... just a bit of a piss off, but its not that big of a deal, and you dont really notice it.
AMT Fast And The Furious 2006 350 Z Night Scream Completed Projects / Gallery 11 02-09-2007 08:07 AM
Model Review: AMT/ERTL - 1967 Mustang Fastback (The Fast and The Furious Tokyo Drift) Flea Car Modeling 0 09-28-2006 07:30 PM
Can a Fast and the Furious Bomex Bumper fit on a Supra with a TRD WideBody Kit NewyorkKopter General 1 09-21-2004 09:05 PM
AMT eclipse FAST AND THE FURIOUS STYLE! Integra14 WIP - Street 47 12-18-2003 10:24 AM
what colors does the fast and the furious supra need for the inside xtreme8799 Car Modeling 1 05-08-2003 10:28 PM
