Old 11-11-2003, 04:55 PM
POPSICLE_PETE POPSICLE_PETE is offline
Send a message via MSN to POPSICLE_PETE
What kind of paint IS automotive paint?
In the paint FAQ, automotive paint is given its own category, separate from lacqour and enamel. But it doesnt say what kinda of paint it is. I used the kind that I get from automotive stores, and the old style cans said lacqour on the label, but they redesigned the labels and the new ones don't mention lacqour. Can anybody shed some light on this. Also how does the paint "attack" the plastic??? I used regular grey primer on my models in thin coats and it seems to work ok. But it there some chemical reaction that I cant see or what?
thnx , popsicle pete
Old 11-11-2003, 05:02 PM
gasman03's Avatar
gasman03 gasman03 is offline
its paint from company's like Duplicolor, Plasticote, its laquer, but, you HAVE to use a primer, or it'll eat through the plastic, i've used Duplicolor paints on a couple models with very good results
Old 11-11-2003, 05:13 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
I amy be wrong but I believe they are acrylic laquers. In any cse they will etch the plastic if you don't use primer, your regular auto primer will be fine
Old 11-11-2003, 05:46 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: What kind of paint IS automotive paint?
yes, they are accrylic laqers, but i have painted un-primered parts with laquer paint and nothing has happened.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-11-2003, 05:54 PM
dag65's Avatar
Re: Re: What kind of paint IS automotive paint?
You can shoot with no primer, but you may get mixed results depending on the particular plastic and the paint. Have you ever tried to trip one you didn't prime? Just curious, I did this on one and the paint etched into the plastic bad and now its green forever LOL
Old 11-11-2003, 09:52 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I used Duplicolor's flat black on bare plastic, and nothing happened. Later, I used gloss black on bare plastic, and it crazed the plastic so badly, and I was puzzled.
It might be a brand specific or even color specific problem.
There might be some products like Tamiya synthetic lacquer, which doesn't damage the plastic, but usually, primer is necessary for an automotive spray paint.
Hiroaki Fukuda
Old 11-11-2003, 10:26 PM
thanks for the help!
Ya, I tought that it might depend on the color too. Sometimes I use tamiya paint as a primer, but that is expensive. But I also use "non-metal surface primer" but it doesnt seem to go o smooth, and canadaian tire only seems to stock it in clear.
Old 11-12-2003, 10:09 AM
z_dutchie's Avatar
z_dutchie z_dutchie is offline
I use duplicolour chrome spray and it's perfect!!
and i don't use primer for that
I also use motip
Frank
feel free to use my name
user bars rock
Old 11-13-2003, 12:28 AM
Rotaryman Rotaryman is offline
Send a message via AIM to Rotaryman
I get the cheap cans of testor's primer from the hobby shop and it goes on smooth as glass. It's only like $2 I believe.
