Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 11-11-2003, 12:17 AM
newmazdaman newmazdaman is offline
Looking to buy a 85 RX-7 with 200k Miles??
Hi imlooking at buying a 85 Rx-7 5 speed it has 200000 miles on the original rotary engine? how much longer can this puppy last? and they wan 500$ canadian for it should i just go for it and worse comes to worse just sesll for parts? and last ? is what are the bad things about RX-7 and the things you should look out for? like i read that you cant stop and go with it? case id do some pizza delivries with it so what do you think thank for your time Moe
Old 11-11-2003, 01:31 AM
DavidovSpeedWRC DavidovSpeedWRC is offline
Send a message via AIM to DavidovSpeedWRC
Re: Looking to buy a 85 RX-7 with 200k Miles??
How is the body, interior and suspension?
If those are in relatively good condition (for an 85) then $500 CDN is not bad at all.
Honestly the motor is probably on its last leg However you can always do a compression test on the motor if you really want to find out how well off it is.
Basically for $500 you can but a cool, old car, rebuild the engine and have a nice daily driver.
OR A MAD CRAZY RACE CAR!
-1987 Mazda RX-7 Turbo II-
Voted #7 in the top 10 cars in 1987 by Motor Trend!
-Driving Sideways Since 2001-
Old 11-11-2003, 08:39 AM
Humanoid Typhoon Humanoid Typhoon is offline
Send a message via ICQ to Humanoid Typhoon Send a message via AIM to Humanoid Typhoon Send a message via MSN to Humanoid Typhoon Send a message via Yahoo to Humanoid Typhoon
better if you buy the body for 300 and order yourself a new engine..200k is near death on an original motor; even if it was kept in extreme care of the previous owner. especially if its a TII engine, it should of blown some time ago. If you have extra money to rebuild the engine or get a new one, all the power to you!
Old 11-11-2003, 10:33 AM
dkennedy dkennedy is offline
200,000 on a RX-7 is a lot, mine has 250,000 and has been smoking and leaking oil for the last 3 years. Here are a couple of things to look for if you expect to get some more miles out of it:
Does it smoke at high RPM? If so it may have been overheated and have damaged seals.
Does the exhast smell like gas? If so have bad appex seals and are only running on essentially half the engine, I drove a 79 for 2 years on half the engine, hard to start sometimes!
Check out the clutch, make sure it feels good and the bearings are not noisy, this could be a pain in the butt.
Finally, take it for a drive, get on it a bit and see if it still has pep, look for smoke and listen for noise.
Oh, you are in Canada, consider the fact it is rear wheel drive and almost helpless in the snow and ice....
David
