View Poll Results: do you like homestarrunner.com?
I do. 0 0%
You should. 0 0%
Voters: 0. You may not vote on this poll
Old 11-10-2003, 08:09 PM
laotionrefugee laotionrefugee is offline
Send a message via AIM to laotionrefugee Send a message via Yahoo to laotionrefugee
Exclamation 91 caravan - low power,won't crank/noise from headlamp/hazard switch when pressed
The battery has proper charge. The engine compartment lamp shines just fine. All interior lamps are very dim. Engine doesn't crank when key is turned. Key point: Whenever headlamps or parking lamps buttons are pressed, there is a noise from behind the dash there. Whenever hazards are pressed, the noise is very loud, like a buzz. Could this be some sort of bad relay? Has anyone had or heard of this problem before?
Old 11-17-2003, 01:36 PM
Angry the fix
It was just the (*&%&^# battery. It was bad. So I spanked it and bought a new one. There are NEVER the same set of symptoms with this caravan when the battery goes bad.
Old 11-17-2003, 07:01 PM
yale329 yale329 is offline
Re: 91 caravan - low power,won't crank/noise from headlamp/hazard switch when pressed
I don't think it's your battery. Check all connections by your batter, by that I mean all your grounds, all connectors. Good luck
Old 11-17-2003, 09:34 PM
the fix II
After fully charging, starting and checking the alternator output and the battery charge after cutting off the engine, the voltage was fine. But 6 hours later, when I needed to drive it, the battery had no charge again. The battery wouldn't hold a charge. So I bought a new one.
