Old 11-10-2003, 01:15 PM
sgniogs sgniogs is offline
Question 02 tahoe keyless entry, Please Help
Just bought a new keyfob for my new tahoe. I bought the truck used, so it didn't come with the originals. I've tried to program it by holding both buttons down but it didn't work.
The remote has
GM15186200
Canada 1096 12021
Model/FCCID: LHJO11
Is this the correct keyfob for my vehicle? If yes is there any other way to program it?
Old 11-20-2003, 09:36 AM
leadwolf leadwolf is offline
You do have the right key fob. Here's how you do it.
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
Later,
Larry Johnson
Dallas, TX
