Old 11-10-2003, 01:04 PM
joey h. joey h. is offline
compression check
whats up guys? i just ran a compression check on a 95 eclipse gst. starting from the number 1, i got 161,161,169, And 180. my question is, do these numbers look good? thats a big jump between number1 and number 4 cylinders. im expecting a bent valve or something because when i rev it up, it sounds like the piston and valve are pinging together. thanks in advance.
Old 11-10-2003, 05:52 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
http://www.dsmgrrrl.com/FAQs/compression.htm
-Agim
Old 11-10-2003, 10:09 PM
kjewer1 kjewer1 is offline
AF - Advisor
The 161s seem a bit low, the 169 is average, and the 180 is good for a 2g motor. Were the numbers dropping as you went along? ITs common for the battery to get lower and lower with each cylinder. Try testing again starting at the other end. Is the high cylindewr full of oil?
If you have a bent valve or anything substantial, you would be lucky to see compression over 100. Its usually 0...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-11-2003, 08:15 AM
well, i tried it again and now 1,3,and 4 seem fine but number 2 has 90 p.s.i. i just changed the head gasket on this thing and torqued everything to specs last week. i found out yesterday that he had turned the boost up backyard style; if you know what i mean. anyway when i rev the motor you can hear a slight pinging noise at the top of the motor. any suggestions? thanks
Old 11-11-2003, 11:38 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
the pinging noise that you hear could be valve lash, when your lifter isnt gapped correctly between the lifter and your valve...i would make sure all your lifters are gapped correctly before goin and taking off the head again!!
Old 11-11-2003, 02:27 PM
what octane do you use?
-Agim
Old 11-11-2003, 04:48 PM
the car has hydrolic valve lash adjusters. (if that sounds right) i dont how how i would adjust them. also, im not sure what octane he is running, but im pretty sure its 93. the pinging isnt a constant noise like valves being out of adjustment, its a piercing knock coming from the top end. almost like its out of time and the valve is hitting the piston. it sound like its coming from the number 2 cylinder. i dont know guys, im stumped
Old 11-11-2003, 08:02 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: compression check
There is NO adjustment in the lifters, because they are hydraulic.
Do a leakdown test and confirm where the loss of compression is coming from.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
