Old 11-10-2003, 01:24 PM
91CRXHF 91CRXHF is offline
Send a message via AIM to 91CRXHF
Break Upgrade?!?!?!?
ok i have a 91 CRX hf hence the name...i did look in the archives but only came out with swapping over the EX and accord thing or the www.fastbrakes.com rear disc conversion... is there anything else out there? anything at all that might be more expensive than the accord ex swap but less than fastbrakes.com thanks for any help guys
Old 11-10-2003, 01:29 PM
Mr. Death Mr. Death is offline
Re: Break Upgrade?!?!?!?
90-93 integra rear disks work I think (not sure)
Old 11-10-2003, 06:24 PM
Thrill91Si Thrill91Si is offline
crx si
I have heard that CRX Si rear disc brakes can be switched in without too much trouble. Someone with a CRX who has done this switch can back me up.
I just switched out the brakes on my hatch with the rear disc setup from a 90 to 93 teg, but I think the parking brake cables are longer for the teg and hatch.
Thrill
1991 Civic Si -- SOLD!
1999 Civic Si
2000 CR-V
Old 11-11-2003, 02:10 AM
91civicDXdude's Avatar
90-91 CRX Si rear disc brakes would be a direct conversion on your car. Also, if you could find the CRX Si rear lower control arms and rear sway bar, you can kill two birds with one stone.
Old 11-11-2003, 02:45 AM
yeah i kinda figured the SI would work as well...but is there anything else out there?...like a company selling new or another car with larger rotors and brakes?
Old 11-11-2003, 02:49 AM
If you upgrade your front brakes, most likely you will have to swap the entire spindle, which means you will have to get different axles.
the 90-91 EX has the biggest brakes of all EF's.
