Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-10-2003, 12:23 PM
chameleon30038 chameleon30038 is offline
Send a message via AIM to chameleon30038 Send a message via Yahoo to chameleon30038
What would be the best type of box
I want to get an Audiobahn System and i know they make boxes also i wanted to know what would be best a Bandpass box, Slot Ported, or Sealed. Please let me know
Thanks
Old 11-10-2003, 12:45 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
For an Audiobahn (assuming that you want SPL) I would go with a slot ported box. Bandpass box is really loud at certain frequencies, but not very all round responsive. Sealed, while loud, is more for a SQ setup. I would say with audiobahn, the slot ported box is the best bet, IMO.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 11-17-2003, 09:44 PM
chstigerpride05 chstigerpride05 is offline
tons of bass= ported
sound quality= sealed
The Flame Audiobahns will blow the plastic out of the bandpass boxes.
Lol
Old 11-18-2003, 12:36 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
the choice is your own. if you have enough power do a sealed if not do ported. When i mean enough power i mean an amp that meets or exceeds the power rating of the sub.
as for flaming q's "blowing" boxes apart wtf do you build boxes with superglue? Try getting the right size box.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 11-20-2003, 01:15 AM
hammerdgolfer hammerdgolfer is offline
Re: What would be the best type of box
audiobahn while looking pretty with al the chrome, has alot of reliability problems, thier bandpass boxes are ONLY for looks and really sound like crap, especialy the triple 12" inverted ones is a joke, ported boxes are more efficient so they need less power to get loud but are also good for spl and sealed is good for sq,
audiobahn really though, think abou tmaybe going with another brand becaus audiobahn is like a bomz exhaust or having a body kit on your car, all for looks,looks overquality and cheap
Old 11-27-2003, 01:51 PM
93DXon18s 93DXon18s is offline
i think the best kind of box is one that is almost completely shaved, possibly a little tuft of hair in the middle, and also one that is not too losse...oh, my bad..................another brain fart from me...oops lol
Old 11-30-2003, 10:23 AM
bc200ex bc200ex is offline
Send a message via AIM to bc200ex
If you get good speakers and a big amp, go with the sealed box. I think it gives the best sound quality and hits the widest range of frequencies. A bandpass box will give you the most boom for your buck (i.e. being loud even with a small amp) but their are some frequencies that just don't hit and when you listen to songs with them it will annoy the hell out of you.
Old 11-30-2003, 02:21 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
This is "borrowed" from the instruction/specs sheet of my Infinity "10 Referance subwoofer speaker and provides what I think is helpful info on different box types and what kind would work best:
The power-handling capability of any woofer is related to both its ability to dissipate heat and the maximum excursion limits of its cone. Once the speaker’s voice coil moves outside the magnetic gap, power can no longer be converted into motion and all the amplifier’s power is converted into heat in the voice coil. This voice-coil heating
is the largest detriment to speaker longevity, so overexcursion should be avoided. Since speaker-cone excursion is different for each type of enclosure, power handling is different for each enclosure.
Sealed enclosures exert the most control over the motion of a subwoofer because the air inside the box acts like a spring against the motion of the woofer cone. Larger boxes allow for more excursion, thus providing more low-frequency output for the amount of power used. When placed in a sealed box larger than the Vas of the subwoofer, it will perform as if it were in an infinite baffle installation.
Vented enclosures have the lowest amount of excursion for the amount of sound output. This is a result of port output reinforcing the sound output from the woofer. The mass of the air contained in the port provides an acoustic load on the woofer’s cone at the tuning frequency, and this added mass decreases woofer-cone excursion. Vented boxes do not provide adequate woofer control when driven below the port tuning range, so proper design is important. A vented bandpass box will have the lowest overall cone excursion, provided a subsonic filter is used.
• Voice-coil overheating and burning due to overexcursion are often caused by overdriving an amplifier into "clipping." A severely clipped signal, or squarewave, contains nearly twice the power of a clean
sine wave at the same level. Bass that sounds broken up and distorted at higher volumes usually indicates that the amplifier is clipping (i.e., being asked to deliver power beyond its rated power).
• Infinite baffle or “free air” mounting applications allow for greater cone excursion than subwoofers mounted in an enclosure. In order to compensate, recognize that the power-rating value of the subwoofer
will likely be half its rated power in this application.
• Study the excursion curves on the enclosed Reference series data sheet and note the differences for different enclosure applications. The type and size of box used will produce different excursion demands
on the enclosed subwoofer and, consequently, different levels of power handling. As long as recommended parameters are used, the subwoofer will perform properly in its enclosed environment. However, any design deviation may result in less than optimum performance, and may also subject the subwoofer to overexcursion (i.e., where the voice coil leaves the gap) that can eventually damage the speaker. For additional help with this issue, please contact your authorized Infinity dealer.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-13-2004, 11:33 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: Re: What would be the best type of box
I had 70 dollar audiobahn high excursions runnign form a JBL BP300.1, my friend had 250 dollar punch HX2's running off of a BP300.1 and mine sounded just as clean and just as loud, im sure if they were actually tested for SQ or SPL thered be a difference but to our ears we couldnt tell a difference. we each built outr own cuztom designed porteed box and both were in 2 door coupes with the subs firing backwards.
personally I think audiobahn is good stuff.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 01-14-2004, 02:34 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
if he had those hx2's running at their rated power he'd have murdered you in spl.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 01-14-2004, 03:57 PM
94tegRS's Avatar
I idnt have mine near their rated power either, im not saying it is better or worse than RF stuff, IM just saying that when you dont have tons of money to spend on 10 watt amps and hundreds of dolar subs, you dont have too. but put the AWT12X with its rated power to the power HX2 with its rated power and I could still do it cheaper the audiobahn way and be probably just as loud. I like RF stuff but why would I spend 3 times as much on a sub that isnt better(well ont enough to justify the price at least)
current
history:
Old 01-15-2004, 05:58 PM
true, the HX2 is grossly expensive
84 Civic 1500S
Old 01-15-2004, 11:01 PM
starkfu's Avatar
starkfu starkfu is offline
Send a message via ICQ to starkfu Send a message via AIM to starkfu Send a message via Yahoo to starkfu
hehe couldn't agree more, although the bit of hair in there may mess up the acoustic wave as it tries to travel to the back of the box.
***If knowledge is power, then a god am I***
<<former PH abyss member>>
1991 Acura Integra GS mods:
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Power slot rotors and EBC pads
Gutted
Blown motor
Looking for B18C5
1994 Honda Accord EX
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Just bought this car, more to come.
Old 02-04-2004, 03:21 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
I'd get a box made of 1/2"-3/4" Lexan... the lexan would be great to build a sealed box out of. stuff is literally bulletproof, and it bends with the travel of the woofer increasing the sound quality. but the cost of the lexan makes it hard if you ever screw up.. and to make the edges clean you'd spend a lot of time with a saw, and lots of sandpaper. But when you're done it'd be the best looking box around, and with a few neons in/around it, it'd be awesome.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-30-2004, 06:36 PM
Icantgetno Icantgetno is offline
Bah the new JL series would far out perform the audiobahn. When it comes to stereos spend the money to make it sound good as well as loud the first time so when you tire of driving around with massive bass and shity sound you can still enjoy your investment.
Closed Thread
