Old 11-09-2003, 10:41 AM
mfmark5007 mfmark5007 is offline
Dohc modification on a Sohc D16Y8
I have a D16y8 (sohc) and i was wondering if there is such a modification to take off the stock SOHC head and replace it with a DOHC head.
basically to turn you EX into and SI???
(i want a DOHC!!!)
if so....can you list some manufacturers or sites?
Old 11-09-2003, 04:30 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Nope no such luck. Don't you think that if it were possible, lots of other people would be doing it instead of spendsing thousands on a swap?
Old 11-09-2003, 05:15 PM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
I think at least theoretically it is possible. One reason I believe people don't do it is because, cost for cost, an engine swap would be less time consuming than having a DOHC head fitted on a SOHC block, since basically you will need to re work the block in such a way as it will not only accomodate the DOHC head, but DOHC internals as well, like its pistons, rods, crankshaft, etc. Not at all practical, given that there are DOHC engines already in the market and at such (relatively) low price. Less work, for what I would assume to be the same amount of money (or maybe even more) that you will invest just to have that DOHC head fitted on a SOHC block. But it would be interesting if you're the first one to do it, and post the total cost of it. If it does prove to at least be the same or a little less than an engine swap, again given that there is a limit to how many engines are built anyway, then it might become an alternative later on to engine swap, and just might provide more life to the aftermarket industry.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 11-09-2003, 05:20 PM
Sure ANYTHING is possible, if your pockets are deep enough.
Old 11-09-2003, 05:30 PM
Milliardo's Avatar
Lightbulb Re: Dohc modification on a Sohc D16Y8
Exactly my point above.
Old 11-21-2003, 09:15 AM
alexngo alexngo is offline
ive heard somewhere that people have put dohc zc heads on the sohc blocks they say it bolts right up but i dont know this for a fact i just read it somewhere and i see people selling dohc zc heads on ebay saying it bolts up just fine as well
Old 11-21-2003, 02:00 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Dohc modification on a Sohc D16Y8
I'll be able to dispell, or up hold that when ever my friend gets a SOHC ZC block.
Old 11-21-2003, 05:24 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
it could be done in theory, but the people doing the work would be asking the question "why?" all the time.
Just swap in a b16 and you'll be fine. I'm doing mine over x-mas break for only 2200. YAY! (cheap cause we're doing it in his driveway)
Name's David.
dohc vs sohc Migra Impreza/9-2x/Outback Sport 18 10-20-2004 08:25 PM
dohc and sohc what is the difference?? kenwood guy Engineering/ Technical 1 07-15-2004 06:36 AM
can i put dohc headon sohc engine mikeypooh1 Neon | Plymouth Neon 0 11-12-2003 11:21 AM
Dohc & Sohc tegusdrifter Engineering/ Technical 2 08-07-2003 02:52 AM
pros and cons zc dohc Vs. sohc Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 30 04-29-2003 04:39 AM
