Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 12-11-2001, 04:20 AM
Brian P's Avatar
Brian P Brian P is offline
Send a message via ICQ to Brian P Send a message via AIM to Brian P
cold starts :(
this is the first winter Lucille will be left outside overnight. now it gets mighty cold here in boulder overnight, mind you. today (at around 5pm) when i tried to start my car it seemed to take forever to start. it had to have been AT LEAST 10 seconds, and that is giving it the benefit of the doubt... possibly up to 15 seconds.
a little after 6-8 seconds i stopped turning the key, waited 3 seconds and tried again. finally it started. everything seems ok.
ive noticed the car taking longer and longer to start as the winter has progressed.. but never over ~7 seconds before. anything i should be worried about?
Old 12-11-2001, 05:46 AM
T4 Primera T4 Primera is offline
Just make sure you have a good battery, antifreeze, and the right weight of oil.
Ever thought of one of those pre-heat systems? ... How far is your car from a power outlet?
How cold does it get? Like this?
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 12-11-2001, 07:10 PM
Brian P's Avatar
i have to park on the street. a heater is not an option
I should think my antifreeze and oil is correct. It always was serviced by Infiniti. I can check the level of antifreeze, but I dont even have access to a garage, so I don't know what I could do about the oil. As for the battery, 1 year ago my mom was driving my car for like 3 days b/c hers was in the shop, and low and behold, she managed to leave the headlights on overnight, draining the battery (...women). I believe that's the only mishap its had. any thoughts?
and as for cranking it... is it bad to continuously crank it? should i never do it for more than a few seconds at a time? or does it not matter?
here is the 5 day forcast for boulder:
Today
High: 45
Low: 21
Tomorrow
High: 30
Low: 16
Thu
High: 43
Low: 12
Fri
High: 46
Low: 19
Sat
High: 39
Low: 18
Old 12-11-2001, 08:39 PM
I don't live where it gets that cold so I don't really have experience with this. Maybe you could have a chat with Infiniti to find out whether this is to be expected or if it indicates something else.
Personally, I don't crank an engine for more than about 5 seconds at a time. No real reason except that the starter motor draws a high current which may cause heat build-up in the electrics. This can create it's own problems. It's interesting to notice that if you crank for awhile, the cranking begins to slow down, but if you stop for 10 seconds or so then try again, the cranking speed returns to normal. I suspect this allows the heat built up in the cranking circuit to decay and lower the resistance of the circuit to normal.
I'm sure there are others on this forum who can help with this. Sorry I couldn't be of more help.
-- Bertrand Russell
Old 12-12-2001, 06:38 AM
fuzzynaval's Avatar
fuzzynaval fuzzynaval is offline
I would find a crazy ass extension chord and use a heater....
Old 12-12-2001, 08:05 AM
hpro123 hpro123 is offline
Possible difficult/impossible start gremlin:
(it has biten me on a B13-SR20DE and few
others so it may be relevant)
On a Classic SER when you first turn the ignition to ON you can hear the gas-tank pump priming for 3-5 seconds (low buzzing sound behind the back seat). Sometimes it does not prime gas andd there is no sound. In those cases the starter turns the engine but there is absolutely no way the engine will start.
Turning the ignition key OFF-ON until the pump is heard priming leads in an instant engine-on.
Chris
Old 12-12-2001, 08:20 AM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
Today
High: 45
Low: 21
Tomorrow
High: 30
Low: 16
Thu
High: 43
Low: 12
Fri
High: 46
Low: 19
Sat
High: 39
Low: 18
Classifieds | Shopping | Travel | Health | Yellow Pages | Maps & Directions | Espaņol
Local Guide | Miami Herald | Entertainment | Sports | Cars | Real Estate | Careers
Wednesday, December 12, 2001 High 82°F Low 71°F Local Forecast & More Weather
WOW glad I am in Miami now and not Philly now !!!
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 12-12-2001, 12:23 PM
cas8_1999's Avatar
cas8_1999 cas8_1999 is offline
Send a message via AIM to cas8_1999 Send a message via Yahoo to cas8_1999
i had the g on a flatbed 2 weeks ago for the trip up to NJ and when i garaged it when i got there it would start fine the next day but when i left it outside it definently wouldnt start and i had to get a jump at least 4 times even in florida when its left outside and its a chili night it takes about 30 seconds sometimes to start
i'm just going to pick up a yellow top battery this weekend and call it a day if it persists then i dont know
casual
i'm at 60k miles now and i think it might be the spark plug time my maintenance is in january
(VXION)PEOPLE ARE IN AWE TO WHAT THEY SEE WHEN THEY SEE YOU (AW 2 DA VI SION)
Old 12-12-2001, 10:24 PM
greekman's Avatar
greekman greekman is offline
brian,
don't you love the cold :finger: i park my g outside also. i have never had a problem w/ it starting. i'm getting a remote car starter for christmas (if santa is good to me) so i have solved that problem. you can pick one up for around 150+, but they have to put an extra part in to bypass the factory alarm and i think that runs around 50-80.
cristo,
malaka! it's nice to see some greeks in here. where are you from (us, greece). i'm in denver, lamia (dad),crete(mom)-xania. as long as my dad doesn't here me say it, eime kritikos.
yasou,
deno
93.5 G20
Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread!
Old 12-12-2001, 11:09 PM
Brian P's Avatar
it wont start now!
dammit dammit dammit i say. one would not expect this from a 3 year, 3 day =) old car. it turns over find... it just keeps going and going and going. about 30 seconds into i noticed the battery light on (or is it always on when you are starting the car). i think i mentioned this before - that 1 year ago it was drained completely from leaving the lights on overnight. i wonder if that didnt screw up the battery somewhat. i know lead-acid batteries are not supposed to be completely discharged under 20%.
so i called Infiniti and i'm waiting for the towtruck. they are going to jumpstart it so i can move it (they are sweeping the street its parked on tomorrow and if i dont move it, it gets towed). greekman why are you not cursed as well!!
i suspect that jump starting it tonight will only be a temporary solution. should i buy a new battery?
Old 12-12-2001, 11:37 PM
I think your battery is fine (30 seconds cranking is good enough). That only leaves 2 things - spark and fuel.
Tried the fuel pump thing suggested by hp123?
Otherwise, when is the next service due?
-- Bertrand Russell
Old 12-13-2001, 12:43 AM
Brian P's Avatar
tow truck guy came. took him about 6 seconds to get it going. he cranked it for 2 seconds. stopped. floored the accerator, cranked it, it sputtered, engine started. he said it might have been flooded. my tank was only 1/8 full. i wonder if that had anything to do with it. from now on i will try to keep it above 1/4 full all the time.
Old 12-13-2001, 12:51 AM
Brian P's Avatar
oh, and its 200 miles overdue for service.
Old 12-13-2001, 12:54 AM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
if you crank the car too much, you could draw too much power from the battery, you could even fry the wires, well i think thats if you crank it for like 30 secs, but its still bad for the wires and the battery.
1.6 - The Underdog
GA16DE-T Club!
Nope, fuel tank has nothing to do with it. Flooded means the engine has had so much fuel in it that it is beyond the range in which ignition of the fuel/air mixture occurs easily. Usually happens on carburetted cars when the person starting the car continually pumps the accelerator pedal - not sure with injected engines. Your car should be able to fire without any gas pedal input from you.
Just a thought, are you filling up at the same place all the time? I recall reading somewhere that, in some places, the fuel sold in winter is changed somewhat from summer fuel. Maybe try getting fuel from another place?
Otherwise, remember what the towie did, so you can try it if it happens again.
-- Bertrand Russell
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
Cold starting in general and runs rough when cold starting searcherrr Windstar 11 12-10-2006 11:42 PM
