Old 11-08-2003, 05:59 PM
dogginit dogginit is offline
Angry '01 Headlight replacement
Has anybody changed a headlight on this model Blazer? How do I remove the assembly in order to reach the bulb?
Thanks in advance.
Old 11-09-2003, 03:33 PM
chicago_guy's Avatar
chicago_guy chicago_guy is offline
Send a message via AIM to chicago_guy
its actually rather easy to take it out. i will use the right headlight as an example b/c it has better reference points. What you want to look for are two plastic clips that are located between the battery and the metal housing around the headlight assembly. They may be kind of hard to get out, but dont be afraid to use a little force (unless it is cold outside, or else they may snap). Once you have found the clips and have removed them, lift the assembly up and out.
To get it back in, however, is a little tricky. You will notice that there are two 'prongs' that slide into slits in the metal surrounding. In order to insert these prongs into the slits, you will have to turn the screw that adjusts the headlight's vertical angle. You want to move it so that if the headlight was still on your car, the headlight would be pointing down. This will allow for you to set the headlight assembly in place with ease, just make sure to set the prongs into place, or else the headlight may fall out while you are driving. Also, make sure to re-adjust your headlight to the proper angle.
I hope i helped.
Old 11-09-2003, 05:11 PM
Re: '01 Headlight replacement
Thanks chicago guy.
Old 11-09-2003, 06:11 PM
No prob. Its my pleasure to help a fellow blazer owner
