Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-08-2003, 01:43 PM
o0Quicksilver0o's Avatar
o0Quicksilver0o o0Quicksilver0o is offline
Send a message via AIM to o0Quicksilver0o Send a message via MSN to o0Quicksilver0o
Question Nitrous ... why so dangerous
Why is nitrous just so damn dangerous....!!!!! I hear of alot of people breaking shit and cracking shit...? Why just nitrous and not tc or sc?
My Current Best 1/4 Mile: 16.832 seconds
My car site
Old 11-08-2003, 02:06 PM
Redrunner Redrunner is offline
Send a message via AIM to Redrunner
Re: Nitrous ... why so dangerous
I run N2o on my car and I know people that have ran it for 5 year or more on same motor. N2o fucks up shit when people start getting dumb with it wanting more power or hitting that rev limit
1999 Honda Civic DX 1.6l I4 (Stock)
Track Best : 17.010 at 80.822 0.070 r/t (THIS IS WITHOUT N2O THIS IS MY STOCK TIME)
MODs:
Real Cold Air Intake (the one that sucks air from under car)
Compucar NOS hybrid wet fogger system (55 shot)
Old 11-08-2003, 08:31 PM
sageprime1 sageprime1 is offline
Send a message via AIM to sageprime1
Yeah man, nitrous isn't really that dangerous as long as you're using it correctly. You should know that all it's doing is increasing the amount of Oxygen in your combustion chamber allowing you to safely increase the amount of fuel to give more power. What's really dangerous with nitrous is that the cooling effect is so dramatic on the seals and piston rings that they may crack. Now on stock cars I don't know how accurate that is, but if you have ceramic seals, like rotary engines can have since they are lighter and more durable, they WILL shatter once nitrous is used. If you hit the revlimiter while shooting nitrous, you could slam you piston into your valve and that's not cool.
HEY...it's not my fault, the car sees u and it sees that u've been defeated!!!!
Old 11-08-2003, 08:45 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Forced induction isn't the safest power-adder either, but like everything else in this world too much of a good thing can create chaos. I blew two stock engines with nitrous and will never use it again, but both times were from user error. I normally pay high attention to detail, so if I can fuck it up, anybody can. I would rather not take the risk so unless you're racing for large amounts of money, it's not worth it (especially just on the street to cruise around).
Old 11-08-2003, 11:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Ok this is one of the dumbest posts I have ever read.
The cooling effect cracking piston rings? WTF and the revlimiter causing piston to valve contact? Come on buddy if you don't kow the correct reply then don't reply. You cpould give some bogus crap of an answer to some one who does not know any better and then they will have a wrong and f**ked up conception of he topic and sound really stupid in front of other people who know what is going on.
Nitrous is only dangerous if you don't know what you are doing.
Old 11-09-2003, 12:45 AM
Re: Re: Nitrous ... why so dangerous
Like i said, i'm not sure with inline or V engines, but rotary engines with ceramic seals, nitrous will shatter the seals. To add to this, if your timing belt/chain is off and you're using some type of force induction, piston to valve contact is possible.
But since your so smart, i have question for you, why is nitrous so popular and not compressed air? Just answer it!
Old 11-09-2003, 01:46 AM
wow such usefull responses!!! i know i can really base a project with educated answers like those!!! i get someone that sounds like they know why and then someone else says they are wrong, and he doesn't have an answer....?
My car site
Old 11-09-2003, 02:14 AM
Trust me (not to be riding anybodys Nutts) but if you have a N2O question go to whtteg He help me more the NOS could. If you want answer go to him I do and my n2o setup is great and my car Faster then it has ever been and maybe will be. And with Np
MODs:
Old 11-09-2003, 02:13 PM
it's all good man....ur right, i would go to people that have years of experience with that too. I was thinkin of nitrous, so i guess i'll know who to seek advice from too.
Old 11-09-2003, 03:43 PM
alright alright i wasnt making jabbs just frustrated but i see how it is and ill ask him some time out of af i guess... uhh thx you all
My car site
Old 11-09-2003, 10:00 PM
whtteg's Avatar
Re: Re: Re: Nitrous ... why so dangerous
B/c the nitrous is 1 molecule of oxygen chemically bonded together with 2 molecules of nitrogen. When the mixture enters the combustion chamber the nitrogen releases the oxygen and the cylinder pressure goes up and there is extra oxygen to burn the extra fuel. Also the air outside is made up of only 21% oxygen where as the nitrous has 33.333% oxygen, so the nitrous is has more oxygen than compressed air. Also compressed air is not as dense as nitrous, the nitrous is cold and is very dense and you can fit more of it into the combustion chambers then the heat causes it to expand, which increases the cylinder pressures, which also helps create more hp. Just so ya know
Old 11-09-2003, 10:11 PM
sideshowrich's Avatar
sideshowrich sideshowrich is offline
2 people short of a 3way
Send a message via AIM to sideshowrich Send a message via MSN to sideshowrich
if your timing belt/chain is off and you're using some type of force induction, piston to valve contact is possible.:
You wouldn't need forced induction to mess up your valves if the timing belt/chain were to break while driving.
Old 11-09-2003, 11:22 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
So then it's not dangerous to redline w/ nitrous? cuz ive heard its dangerous too, expecially with a engine that redlines high like a type-R? and also is it more harsh on your engine to use nitrous in 1st gear than the rest?
Old 11-09-2003, 11:57 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
The original question, its kind of loaded. I know some people (and im sure some guys on here) have run N20 for a long time without much trouble. Basically the people you hear about who are "cracking stuff" are the poeple who think n20 is just free horsepower and they don't need to do anything to their car to get it to work. Your effectively doing the same thing that a turbo is doing, your just putting more oxygen into the cylinders, and if there is too much air and not enough fuel, then your run lean and blow stuff up. You must supplement a large boost of n20 with an equivilant fuel system upgrade and timing corrections, and if you get big enough (or crazy enough), you need pistons and rods to handle all the new power.
Now im sure there are plenty of stories of people who say you don't need to upgrade anything using n20, but I don't believe them and they are the ones who usually post about cracking stuff. But for small shots of n20 the stock system is usually adequate (as far as I have seen). I know if you want to be safe you should upgrade your fuel system with any signifigant increase in horsepower. And every time you upgrade something, you have to ask yourself if your ready to accept the risk of something going wrong. So I say its better to be safe than sorry, much cheaper to upgrade before something breaks, then to wait for it to break and rebuild your engine later.
"You wouldn't need forced induction to mess up your valves if the timing belt/chain were to break while driving."
Yea that guy is crazy, if your timing belt breaks or youve got it too far advanced, you dont need anything to help you screw up your engine, you just did it yourself. Although he might be referring to the fact that when you boost, you have to retard your timing a little or risk predetonation.
But piston to valve contact? It doesnt take anything special to do that, its either going to happen or its not. And if you didn't test this before your large cam install or new pistons then... youve got other problems.
And whtteg hit it on the head with the n20 description, probably another reason for using n20 over compressed air, is that you can get n20 to liquify and put alot in the same bottle size, I doubt thats possible with just regular outside air, or at least safely and economically.
So to sum it up quicksilver, go ahead and use nitrous if you want, its not so much dangerous if you respect it like any other upgrade and make sure you don't get too greedy without proper upgrades, thats when you get into trouble.
my safe
HTH
Buzz1167
Jon N
Old 11-10-2003, 01:22 AM
Ricochet's Avatar
Banned
Nitrous is the worst power adder for regular street use anyways. You gotta build up your engine so much to run a safe shot, but you're still stuck with having to fill the bottle and worry about the pressure all the time. After it's empty you're stuck knowing you're slower than you could be, while if you had a monster n/a or boosted car you could whoop ass over and over all day long.
Just think about it... you get your first bottle and let loose all over the freeway. Then the next morning you get up all excited, go speed around the freeway some more, but it gets weaker and weaker until you hardly feel the shot anymore. Then on your way back home some riced out Si with some boltons wants to race you, then wins because you're on E. I've been there and it sucks, because "If only I had a full bottle" I could have beat him on my sohc. I wish I would have put all that money into a turbo or good engine swap back in the day. Instead I kept buying part after part thinking "this is it, this part will make me happy".
Point is, save for a more permenant and reliable source of power.
My safer
Why a "little" knowledge is more dangerous than alot.. T4 Primera Politics, Investments & Current Affairs 2 02-01-2005 11:26 PM
Why I'm not a fan of nitrous... duplox Mustang Talk 5 07-21-2004 12:47 AM
Why only nitrous?!?! drag1320neon Forced Induction 25 04-30-2004 07:20 AM
