Old 11-08-2003, 02:11 AM
sporty sporty is offline
fuse location
Hi, I have a 2000 Grand Caravan Sport. My left and right turn signal isn't working. There's no blinking and no dash indicators lights on. I tried looking for a blown fuse under the driver's side dash but none indicate a turn signal fuse. There no diagram of the fuses on the cover. I'm wondering if anyone can help me locate the right fuse to check....Thanks
Old 11-08-2003, 12:41 PM
michellehsalgado michellehsalgado is offline
Re: fuse location
Look under the hood and to the right of the battery-the main fuse box should be there.
Old 11-09-2003, 01:05 PM
Re: Re: fuse location
Thanks, I found the box but there were no fuse labeled for the turn signal. Would you happen to know where the flasher is located?
Old 11-09-2003, 02:21 PM
proticus's Avatar
proticus proticus is offline
Re: fuse location
don't you hate it when those things aren't labeled? There is a list of which fuses are which in your vehicle manual.
Old 11-10-2003, 05:26 PM
Talking
Try Cavity 12 and a 10 AMP (red) fuse. You should have cavities numbered 1-16 and 12 is the last one on the right of the single row of fuses. #11 should be just to your left and will be blue. The part #'s for the replacement bulbs are as follows: (incase you need one of those, too.) Interior turn signal indicator: PC194 and Exterior Turn Signal Bulb: Bulb #3057. Hope this helps.
Old 11-13-2003, 08:26 AM
yale329 yale329 is offline
Re: fuse location
First check the bulbs. A lot of newer vehicles do not display or number the fuse boxes under the dash. A quick way is to have a helper watch the lights with your ignition on. Use a metal paper clip and bend it so you can connect the two metal tabs on top of the fuse. You will then have direct current and shoud be able to find out which fuse is malfunctioning, if that is the cause. The only other alternative is to remove one fuse at a time replacing it after inspection so you don't get mixed up.
Old 11-13-2003, 10:00 AM
tazman tazman is offline
The list of fuse locations should be stamped on the underside of the fuse box lid. It is also listed in the owners manual.
Old 11-15-2003, 01:05 AM
Re: fuse location
Thanks everyone for the help but I found the problem. It was a bad flasher relay located on the fuse box under the dash. It's the long black relay that larger than the others in that area.
Old 03-07-2004, 12:55 AM
caravaner5000 caravaner5000 is offline
Lightbulb Re: Re: fuse--bad flasher relay
Hello,
[QUOTE/]bad flasher relay located on the fuse box under the dash. It's the long black relay that larger than the others in that area.[/quote]
How much did that cost and could you do it yourself?
Old 03-09-2004, 01:16 AM
Re: Re: Re: fuse--bad flasher relay
Originally Posted by caravaner5000
Hello,
How much did that cost and could you do it yourself?[/quote]
It costs about 55 dollars. It took me about 30 seconds to install!
1995 Ignition (start) circuit fuse location (fusible links)? Won't turn over. flagged Cavalier 4 06-27-2004 08:22 PM
Keyless Entry Fuse Location?? Biggstic Expedition 0 11-29-2003 05:37 PM
PLZ Where is the Gas Pump Fuse Located??????? Honda_Racer '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-23-2003 09:30 AM
fuse location 93 S-10 Blazer jmerle Blazer 2 02-04-2003 06:03 PM
Fuse Locations? Stealth Celica 0 10-10-2002 02:36 PM
