Old 11-07-2003, 07:37 PM
fujimituner235's Avatar
fujimituner235 fujimituner235 is offline
Send a message via AIM to fujimituner235
Wet Coat?
I heard of this, but exactly how does it work when you paint/prime? How does it help?
"I like you...but you're crazy.....you're crazy man" -Will Ferrell (old school)
Old 11-07-2003, 07:48 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Wet Coat?
uh... i think i understand what your asking.. primer helps to make the paint stick better.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-07-2003, 08:07 PM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
Wetcoat....when painting the model it is advised to spray the first couple of coats as a mist. The primer (or plastic if you are so inlined) should still show through the paint. You are trying to build up coverage in stages. The wetcoat is usually the last coat of paint. Sprayed a bit heavier than the rest. If done correctly, the paint should look smooth and very shiney...wet.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 11-07-2003, 08:09 PM
Sebstar's Avatar
Sebstar Sebstar is offline
wet coat is used in painting so as to make the surface look shiny. I don't think you'd really use a wet coat for priming, as you only want the car to be lightly sprayed (and covered) with some primer, in order for the laquer to stick to it. Usually the wet coat is the last coat of the painting process, the one that makes the Pman shine
i hope im right, lol
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Wet Floor on Driver's Side of 97 Laredo Laredo1 Cherokee 2 03-06-2009 11:12 AM
Airbrush Help Wet coats joelo59 Car Modeling 2 01-02-2005 02:19 PM
Need help, wet coat gone bad Trovão Aurora Car Modeling 2 04-03-2004 11:02 PM
How many coats of clear coat? BOOSTD Car Modeling 1 05-07-2003 02:31 PM
