Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-07-2003, 02:57 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
Dropped Teg-need camber kit?
hey whats up
im gonna drop my 97 integra with some arospeed springs. first off, are they decent springs? im gonna be spend n the most about 130 for the springs, so do u guys recomend any brands? eibach and neuspeed looks too much for me.
also, the car is gonna be dropped like 1.5 to 2 inches, so is it necessary to get a camber kit? or will my tire wear not be too notciable w/o the camber kit?
Old 11-07-2003, 04:35 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
I dont think you really will need a camber kit. I bought one, and I regret it, cause of other problems. I'd recommend H&Rs. Its been said many a time, don't go cheap on your suspension, you might end up having to do it again. Neuspeeds are good too, practically the same compny.
Old 11-07-2003, 06:44 PM
BigBoyB's Avatar
BigBoyB BigBoyB is offline
what about shocks? are new ones necessary for a decent ride with that amount of drop? or will the stock shocks be ok?
lets roll[/font][/size]
Old 11-07-2003, 07:00 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
i definately reccomend u get a camber kit. when i bought my car it was already lowered to about 1.5-2.0 inch. after a couple of months the inside of tires were bald and the outside were still good. but instead of buying a set of tires every couple of months i made the right choice of installing a camber kit. if your going to get a kit, don't be cheap it will pay off in the long run. i got the best, they are from ingalls and have never had any problems. also once u install them make sure u get an alignment and alignment check every 6 months.
FS: Springtech 1.75 inch drop springs and camber kit Pontiacracer99 Grand AM 1 08-22-2004 09:16 PM
3" drop Is a camber kit needed? TheSilentChamber Wheels/Tires/Suspension 11 06-07-2004 06:15 PM
do i need camber kits? CraniumDesigns '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 10-31-2002 05:34 PM
need camber kit??? bruzer Tires and Wheels 3 03-22-2002 10:20 AM
Lowest drop before needing camber kit? jmgladden Suspension 18 09-22-2001 10:31 PM
