Old 11-07-2003, 02:18 PM
gex32985 gex32985 is offline
Exclamation air/fuel ratio
i bought an air/fuel ratio gauge electric and i hooked up to my front o2 sensor under the manifold into the white wire coming out of the o2 sensor... i notice there are 2 black wires and a blue and white coming out of that o2 sensor so i got a diagram and it said the white wite is the o2 sensor signal wire.. but i have a problem - the air/fuel ratio gauge just stays in one spot on lean and doesnt move to neutral or rich just stays right on lean.. can someone help me?
Old 11-08-2003, 01:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
Your best bet is to hook it up at the ECU, not the sensor. The colors change at the plug. So go to the vfaq site and get the pin number. Its also very important to use the ECU ground. The AF guages are shady as it is, and using a non-ecu ground will make it way off.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-08-2003, 10:57 AM
could you tell me where the ecu is located in the 2000 eclipse gs?
Old 11-08-2003, 11:57 AM
AF - Advisor
Hmm. I mistakenly assumed you had a 1g/2g. I have no idea where it is in the 3gs.
Kevin Jewer
Air/fuel ratio crewchief264 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 01-25-2003 05:05 PM
How do I measure air fuel ratio riceburner Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 11-07-2001 08:37 PM
air/fuel ratio meter lockemiester Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 09-23-2001 02:21 PM
Air/Fuel Ratio Gauge!!!!!! XtremeHKS Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 07-31-2001 12:59 PM
air/fuel ratio meter?? ptrkng Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 06-05-2001 09:47 AM
