Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 11-07-2003, 02:14 AM
89 Turbo1 89 Turbo1 is offline
Engine problems
1989 2.5 turbo 1
According to this my car should get to 11psi at around 4500 rpm. My car at around 3500rpm falls flat in its face and has no power. The highest I have ever seen my boost is 7 psi. Before 3500rpm it fells fine. After 3500rpm it feels like I have no power at all. What could be causing this?
Old 11-07-2003, 01:37 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
The fact is that the Turbo I was set to run 7 PSI. Also your Turbo I is using a small Mitsubishi TEO4H turbo unlike the pre 1989 Turbo I which used a larger Garrett T03 unit. Your turbo will spool fast but it won't have much high end boost.
1998 Chevy Lumina Engine Problems? Engine Swap to 3.8 jonfit04 Lumina 12 11-10-2010 08:15 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 02:25 PM
