Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-06-2003, 11:43 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
Radio reseting codes
whats up
i just got a 97 integra LS and im going to hook up an apex-i S-afc this weekend. to do this i will have to disconnect the negative battery cable. i read in the Haynes manual that if u remove the negative battery cable from the battery that u will have to enter the stereo reseting codes once u connect it back to the battery. i dont have these codes... so does anyone know where i can get them? Also is there anyway to remove the negative battery cable w/o causing the radio to be reset?
thanxs
Old 11-06-2003, 11:49 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
Maybe you could just pull out certain fuses. Nah, just get a new CD player. They're not that much, and all you have to do is splice a few wires.
Old 11-06-2003, 11:54 PM
BullShifter's Avatar
Re: Radio reseting codes
You can purchase a "memory saver" that plugs into your cigarette lighter with a 9volt battery attached. They can be found @ most auto parts stores.
Since you do not have the code, it would be wise to get it. First thing check in the glove box or center console for a little white sticker containing the radio serial # & radio code # - only some techs do that during the PDI. If it isn't there, its time to remove the radio & go to a honda/acura dealership w/ car & radio. They can run your VIN# w/ radio serial # to come up with a code - if your radio was changed, most likely the code is wrong. Also the orginal selling dealership may have the code on file in the PDI history or deal bag.
If you can't remove the radio yourself then the dealer will charge 1.0 hr of labor for R&R of radio, this has to be done because the serial # is located on the top/bottom of the radio. Some cars you can pry the trim just enough to peek in there without removing.
Old 11-07-2003, 12:13 AM
thanxs for the heads up. im go n to check my glove box and center console tomrrow. i was just search n for threads just like this one and one member said that the code might be in the fuse box under the hood. i'll give it a look. if i cant find it i'll just take the car to an acura dealer and ask them for the code.
thanx again
PLEASE HELP! Daewoo Nubira Radio Reset Code jen25sg Nubira 14 02-22-2013 03:57 PM
Keep having to reset code on radio STEELERFAN86 7 Series 0 07-07-2008 09:21 PM
95 sonata radio reset code hardworker Sonata 0 02-08-2006 01:15 AM
Radio Reset Code postonra Integra 1 08-04-2004 11:45 PM
