Go Back   Automotive Forums Car Chat > Dodge > SRT4 > Performance
Old 11-06-2003, 05:58 PM
Projectcivic96 Projectcivic96 is offline
Send a message via AIM to Projectcivic96
Srt-4 motor swap possible?
I got a 96 neon sport coupe and was wonderin if it would be possible to swap in a srt-4 motor. I wanna do it because ive never heard of anyone doing it plus it would be different. Anywase i know id need to change the whole wiring harness and shit but i just need to know if its possible to do. If so would anyone happen to know where i could get the motor at. Any suggestions would be greatly appreciated.
Thanks,
Matt
Old 11-06-2003, 10:59 PM
only_dodge only_dodge is offline
Thumbs up srt-4 motor swap
anything is possible. you just gotta be sure what your doing. i found a website a while ago where they put a 2.4 turbo motor in a neon, which is the same as the srt-4 motor.i will try to find it and pass it on
Old 11-07-2003, 01:51 PM
please do i could really use it.thanks
Old 11-09-2003, 09:22 PM
jaronervin jaronervin is offline
Send a message via AIM to jaronervin
I've heard that the SRT-4 engine will fit under the 1st generation neon hood, but you'd have to do some mods to get the motor mounts set up right.
Old 11-10-2003, 12:22 AM
supr60tsi supr60tsi is offline
a first gen eclipse motor will go into it,go turbo 4g63 and have gobs
of horse power. how many turbo neons do you see running the roads?
Old 11-10-2003, 11:48 AM
diablo25mn diablo25mn is offline
www.neons.org there are plenty of 2.4 swaps on there, some nasty n/a, some spraying, some turbo'd, and some turbo'd and spraying. The srt4 engine wouldn't work in a first gen, thier wiring systems run completely different not to mention the way the ecu's work, and finally it doesn't fit in a 1st gen neon.
Old 11-10-2003, 06:05 PM
Re: Srt-4 motor swap possible?
Actually, I've seen plenty of turbod neons... SRT-4? .
Old 11-11-2003, 03:44 PM
so you have, but how many 1g neons turbo'd have you seen?
Old 11-11-2003, 07:22 PM
not as many, very true. I have seen a couple, however. But not many.
Old 11-11-2003, 10:35 PM
Scatch! Scatch! is offline
I'm with Diablo: it won't work, at least not easily or practically. You might as well take an older 2.4L and turbo the sucker.
There are G1 turbo Neons out there (I have a friend with a very quick, fast SOHC turbo), but they certainly aren't thick on the ground. Hell, there are probably ten times as many turbo'd Civics and they aren't all that common.
Old 11-12-2003, 06:54 PM
well, since there are so few turbod G1 neons, I'd have to go w/ that and be different!
Old 09-14-2006, 03:13 AM
whitemanstag whitemanstag is offline
to all of you that doubt the swap you're wrong. it isn't that bad. i'm starting the project. goto neons.org and it tells you what you need to know. modern performance sells the motor mount adapter you need for only 70 dollars. the wiring out of a first gen will work.
Old 09-14-2006, 04:27 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Old thread!!!!!!!!111!one!!
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-18-2006, 05:26 PM
breckboarder55's Avatar
breckboarder55 breckboarder55 is offline
so if its an old thread its still an interesting topic, and anyposting is better than no posting
yes its been done, but its gonna require alot of one off fabrication with mounts and what not... If you are to do it; it would take a good chunk of money.... but i say go for it if you really want to and i wish you luck
1987 MAzda RX-7 TII built motor, every bolt on, big turbo, standalone, everything, exc.exc.exc. Easily 400+
1955 Dodge Royal Lancer Super Red Top HEMI
Old 08-14-2007, 10:58 AM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
here my understanding, don't the newer neons share the same 2.0 as the old 1st gen neons? The srt4 is basically a modern day neon with a beefed up 2.4 thats boosted. to me it seems logical that the srt4 motor should just drop right in. i'm sure this topic has been talked about before if not been accomplished on a 1st gen neon.
Heres the thing though, why go through the trouble of swapping in that 2.4? check out hahns racecraft they are very big into neons and they make turbo setups that are pretty nasty.
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Im looking into buying a 2004 neon srt-4. Help? taylorj_92 2nd Gen 00-05 0 12-18-2010 02:18 PM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
Srt-4 motor swap please help Dragit 2nd Gen 00-05 1 07-02-2006 02:42 PM
Motor Swap Srt 4 motor in a plymouth breeze Breezin Breeze 1 03-22-2005 08:56 PM
Srt-4 motor swap Neon1996 Neon | Plymouth Neon 7 02-16-2004 09:49 PM
