brakes
I just got done replacing the entire brake system on my 1971 camaro last night , started it up and backed it out of the garage(after properly bleeding all brakes-drums on back disk up front non power all around(too high cam lift)) and i can litterally put my foot on the brake as hard as i can, give it some gas and take off. Oringinally it only needed a new master cylinder, but i thought i should replace all of it since it is all original. New parts include:
-front lines(hard and soft) -rear lines(soft line and hard axle line) -master cylinder -calipers -rebuild kit for rear drums all parts are from the Paddock and Master power escept for the calipers which i got referbished from a local shop. I have brakes, but they work worse than a car with manual drums all around. The pedal is hard, but the brakes don't operate correctly. I have a feeling it might be the proportioning valve, because when bleeding them, fluid came out the back faster then the front. Before spending more money, i would like to be sure what the problem is. ANY help is appreciated! |
Check the plunger before the master cyllinder. It SHOULD be adjustable (if it's vaccuum assist). Try shortening or lengthening the plunger to see if it makes a difference. I had a 76 corvette that had a problem with the brakes. Front brakes would lock, but the rear wouldn't even start to brake. Screwed in the plunger and sho-nuff.. no more problems. If that doesn't help, then check the proportioning valve.
Good luck. |
Proportioning valve
I knew about the plunger, thanks for that though, I just ordered a new proportioning valve from Master Power, if that doesn't work, it's a$1200 dollar system from Baer! lol.
Re: brakes
HI! 19camaro71
did you fix your brakes??? how? |
