Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 11-06-2003, 05:56 PM
grui76 grui76 is offline
Send a message via AIM to grui76
Cool stop light trouble shooting on an 95 altima
i have a 95 altima that is leaving the stop lights on. i have replaced the brake light switch, but the problem still is still there. does anyone have anty idea of what may be causing the problem..or where i could go on line for help? i am a do it yourself type. :
Old 03-16-2004, 03:32 PM
240slider's Avatar
240slider 240slider is offline
Re: stop light trouble shooting on an 95 altima
check your brake pedal adjustment it might have to much freeplay maybe not enough to start braking the car but enough to close the circuit to light the brake light up .
Old 10-08-2005, 01:10 PM
mike171562 mike171562 is offline
Im having the same problem, i got under there and played with the switch, the brake lights stay on when the switch is depressed, not depressed and even when the switch is removed entirely, does anyone have any suggestion to this problem??
Old 10-29-2005, 01:51 AM
SteVB SteVB is offline
brake lights
See The Last Thread, There Are 2 Rubber Plugs That Go Bad Where The Upper Brake Pedal Contact The Brake Light Switch & The Cut Off Switch For The Cruise Control, That Break & Fall Out. These Need To Be Replaced With A New Plug, Or I Just Used A Short Bolt & Nut. If Your Switch Button Just Sticks Thru A Hole In The Brake Pedal Bracket, Then The Rubber Plug Fell Out & Your Lights Wont Turn Off Till This Is Done.
Old 11-07-2005, 08:55 PM
Re: brake lights
thanks, that did it
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 04:56 AM
2001 Caravan Stop lights out RickCox Caravan | Voyager 0 04-05-2010 02:13 PM
fuel system trouble shoot veedubdan Jetta/Vento/Bora 4 01-20-2004 01:07 AM
check engine light on need more help trouble shooting jkm81 Ranger | Courier 7 12-22-2003 04:43 PM
trouble shooting! velocitySiR Engineering/ Technical 3 07-14-2002 02:00 AM
