Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-06-2003, 12:28 PM   #1
Tom Youngblood
84 Cutlass Starting Problem
I have a 84 2 door Cutlass Supreme with a Buick 3.8L engine. When I turn the engine off and try to start it later, the voltage guage shows 8 volts and the engine barely turns over. I can wait anywhere from 10 minutes to several hours and then it will crank. It doesn't do this all the time and sometimes it does this the first time I try to crank it in the morning. This leads me to believe it's not a heat problem. I have been unable to find any shorts or possible shorts (frayed wires) up to this point. Any advice on where to start looking? Also, since I found this forum (thankful for that), I have a question. My Cutlass has an automatic on the floor. Most of the pictures I am seeing show the shifter on the column. Was this an option or do I have something besides a 2 dr notchback coupe? Thanks
Tom Youngblood is offline   Reply With Quote
Old 11-07-2003, 12:49 PM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
First thing I would look at is the battery..have it load tested.
Sometimes batteries can develop internal problems that can cause the problems you are descibing.
Many Cutlass's came with floor shifters
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 11-17-2003, 12:21 PM   #3
Tom Youngblood
Thanks, had the battery checked early on and they said it's ok.
Old 11-19-2003, 04:05 PM   #4
RABarrett
I would check the battery terminals. After attempting to crank the engine, check the terminals. The hot one needs attention. If all is well there, I have seen alternators fail, causing the engine to be very difficult to turn. The check here is to disconnect the serpentine belt and try again. You might have a friend try cranking the engine and watch the alternator. If it tries to turn the opposite direction from the engine, it is likely the culprit. You may also have issues with the starter, in which case, both battery terminals will be the same temp and hot. Be careful when checking this. The defective terminal could be seriously hot... Ray
RABarrett is offline   Reply With Quote
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 06:56 PM
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 05:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 12:13 PM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 08:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
