Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-05-2003, 05:45 PM
regz12 regz12 is offline
Isuzu Rodeo TICKING NOISE !
I Have a 94 Rodeo and when iam stopped it makes a enoying TICKING sound.I Herd that it was the lifters that needed lubbing ... but i dont know how to get rid of it any help?
Old 11-05-2003, 05:58 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
go to your local autozone or O-riley store they should carry a product called seafoam buy it and follw dircetions on the bottle
Old 11-05-2003, 10:30 PM
Thanks Alot !
Old 11-05-2003, 10:40 PM
911S_TARGA_RSR 911S_TARGA_RSR is offline
Re: Isuzu Rodeo TICKING NOISE !
It could be your timing is off or your spark plugs are misfiring. But try the Seafoam it might help.
911 Super Targa RSR
[Dual Flow Intake][Twin Turbo][Larger List to Come]
Old 11-05-2003, 10:43 PM
what kind of seafoam should i buy ... Auto Marine , Trans Tune , Or Deep Creep?
Old 11-05-2003, 10:49 PM
I recommend Deep Creep
911 Super Targa RSR
Old 11-12-2003, 10:52 AM
rayb rayb is offline
I have the same ticking that you are talking about.Mine is a 95 model.What is that seafoam stuff you guys were talking about?What causes the ticking?
Old 11-12-2003, 09:55 PM
restricted oil passages in lifters due to lack of or poor maintenance
Old 11-19-2003, 03:39 PM
Someone told me they used CD-2 Oil Detergent on there 96 rodeo and the noise was gone!
Old 11-19-2003, 09:35 PM
ibew595's Avatar
ibew595 ibew595 is offline
Send a message via AIM to ibew595
I have had it for a LONG time, tried the CD-2 and it kinda works. Best bet for me is full sythetic oil changing it every 6k or so. Normal oil would break down and cause the lifter noise again. I will have to look for the seafoam stuff, I have never heard of it.
cheapest fully sythetic oil I know of is BMW oil, +/-$3.88 qt
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
Old 12-01-2003, 03:49 PM
Rmasters3 Rmasters3 is offline
Ticking
I used a quart Rislone with 5-30 oil. Noise went away and never came back.
Tried everything else, and nothing worked.
Old 01-25-2004, 09:28 PM
danforth45's Avatar
danforth45 danforth45 is offline
I have a 97 3.2 rodeo with the same ticking problem. I have been running 5w30 mobil1 for 2 oil changes now and it helped the noise slightly but it is still there. I heard that if you drain a quart of oil out and pour a quart of auto tranny fluid in and run for about 30 min it will cure the tick! I will try it next oil change.
Rmasters3.......... what is rislone?
Old 01-26-2004, 06:04 AM
Re: Re: Isuzu Rodeo TICKING NOISE !
Rislone is an engine oil additive that has been on the market forever. I have used it over the years, particularly when I get a used car and I am unsure of the frequency of oil chnages. It's, among other things, a high detergent product. My usual drill is to add it and change the oil several times in the next 1000-1500 miles, sometimes I use it thereafter, sometimes not.
I used it in the Rodeo, and the noise went away immediately never to return while I owned it. I had tried other weights, blends and sythetics, none of which worked.
You can buy Rislone at any parts store, K-Mart, etc. It's about $2.99 a quart.
I have never used it with synthetic lube, and don't know whether that's recommended.
The Following User Says Thank You to Rmasters3 For This Useful Post:
slxdrvr (12-06-2011)
Old 01-26-2004, 06:10 PM
you can add 1 qt of tranny fluid with your oil every time you change it you will not harm your engine
Old 01-31-2004, 09:13 AM
KitCatJMS KitCatJMS is offline
Send a message via Yahoo to KitCatJMS
Does your car only make this ticking sound when its close to an oil change time? I have a 95 that does that ... It usually tells me my oil is getting low (or rather, lower than my car likes) ... if I add a little oil and take it in for an oil change within the week it stops ticking ....
2001 Isuzu Rodeo p0463 furgo Rodeo | Passport | MU 6 11-14-2011 08:05 PM
Isuzu Rodeo Runs HOt WNathan67 Rodeo | Passport | MU 1 07-03-2010 08:29 PM
93 Rodeo cranks but won't idle. Help! hansola Rodeo | Passport | MU 1 04-13-2009 08:00 PM
95 Rodeo, 1st gear will not kick in.... RedRodeo Rodeo | Passport | MU 0 04-06-2009 09:07 PM
98 Isuzu Rodeo Ticking/Rattling problem solved finally kallake Rodeo | Passport | MU 5 05-19-2006 10:19 AM
