Old 11-05-2003, 03:14 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
how do i remove my alt belt
i need to chage my alternator belt and i need to remove it to go buy another one how do i remove it ? what pulley do i need to loosen ?
Old 11-05-2003, 03:18 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
To the rescue...! Sorry, couldn't resist
Removing the alternator belt is easy. Just loosen the top bolt (the one that bolts through the top alternator bracket - just below your intake manifold). Once that bolt is loose you can pull the alternator forward enough that the belt will come right off.
You don't have to remove or loosen the bottom bolt. The alternator will pivot back & forth with just the top bolt loose.
how to remove serpintine belt, '94 3L caravan bombergp Caravan | Voyager 3 05-06-2006 01:15 PM
how to remove timing belt on 99'?? Confused and in a rush hochy Cirrus 1 04-05-2006 01:47 AM
anyone know how to remove the Belt Tensioner Assembly ford460bigblock Cavalier 2 12-31-2005 10:47 AM
How do I remove seat belts on 99 cavalier? menaztricks Non-Performance 2 11-26-2005 11:53 AM
