Old 11-05-2003, 12:31 PM
Clevj001 Clevj001 is offline
Molding and emblem problem
so my friend talked me into taking off the molding on my truck now i got these two long stripes of the tape along each side of my truck
ive tried just about everything and nothing will take it off unless i sit there for like 4 hours
is there anything that will work?
whats the best way to go about it
thanks
justin
[email protected]
Old 11-05-2003, 01:46 PM
bim's Avatar
bim bim is offline
Send a message via Yahoo to bim
For next time heat up the molding with a heat gun to soften the tape and make it easier to take off.
As for now, have you tried aftalene?
Aftalene works very well on glue without hurting the paint. But be careful, if you rub too long on the same spot you will take off the finish of the paint. Use an old clean rag, pour a descent amount of afta on the rag and saturate the leftover 3m tape. Let it sit for about 2 minutes, then try to rub off the tape starting from one end. After you get it all off don't forget to wax the area that you were working on because aftalene takes off all wax and dirt.
Old 11-05-2003, 02:59 PM
i never thought of using the heat gun thats a great idea
thanks alot ill try it
justin
Old 11-05-2003, 03:23 PM
rositis's Avatar
rositis rositis is offline
yeah i took the molding off the side of my truck. got the 03 silverado regular cab and the molding was short and gay and looked like it was missing from the bed. anyway i used a heat gun and it took me about 10 mins to do both sides and it didnt leave any signs that the trim was there. as for the residue you still could use a heat gun and heat the tape up and rub it off with you finger. it should just ball up into a ball. thats what i had to do with a little bit of mine and it came off no problem. just dont heat it up to much and dont burn your finger cause the tape will get hot.
Old 11-05-2003, 09:35 PM
thanks sounds like the heat gun is the best way to go i will be trying it
Old 11-06-2003, 10:11 AM
bim's Avatar
bim bim is offline
If you still have a little residue left over after you use the heat gun try using the Aftalene. They sell it in Home Depot and Loews so it shouldn't be hard to find.
Aftalene is a cleaner that body shops use to remove wax and residue from paint without damaging the finish. It also works excellent on old pinstriping that is coming off.
2002 1500 Ext Cab w/ 5.3L. Modifications coming...
Old 11-06-2003, 11:22 PM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
3M Adhesive remover works well too. I soaked it with that and let it dry a bit and it practically fell off.
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 11-07-2003, 01:31 AM
ok cool SC CUSTOMS
NICE TRUCK I LIKE THE AIR DAM
DID YOU CHROME PLATE IT OR BUY A CHROME METAL ONE
THAT LOOKS TIGHT
AND DID YOU PAINT THE PLASTIC RED YOURSELF?
IF SO HOW CUZ I GOT A WHITE ONE AND I WANT TO PAINT IT ALL WHITE
THANKS ALOT
JUSTIN
Old 11-07-2003, 03:25 AM
sc_customs's Avatar
yeah i bought the chrome air dam online...Distinctive truck parts makes it but I got mine at stylinconcepts.com. I had the paint done at a body shop. they only charged me $150 for paint and body work on the bumper and the grill. I was gonna do it myself but for that price I just had it done. If you wanna do the body work yourself I could tell ya how. just email me. later.
K&N Fipk Gen. II
Poweraid TB Spacer
Whipple on hold
Old 11-07-2003, 03:37 AM
yea seriously for that price id have em do it to where did yuo get it done cuz im out here in long beach ca and i noticed you are in ca as well
thanks
justin
Old 11-07-2003, 06:16 PM
bim's Avatar
bim bim is offline
You could also try www.pccustomcycles.com Phil does all chroming polishing powder coating and his chrome work has a 1 year warranty on it. He even chromes plastics.
Old 11-09-2003, 10:47 PM
1991FZR600 1991FZR600 is offline
Re: Molding and emblem problem
thanks
justin
[email protected]
Hair dryer and Goo Gone took me 11 minutes to debadge/demold my 03' Silverado. I also took the pinstripes off of my old 92' Lumina like that.
Old 11-11-2003, 10:00 AM
bowtieguy bowtieguy is offline
hair drier is the best bet like mentioned above but if you have already removed them and have just the residue then Goo Gone works great and is cheap.
Old 02-02-2004, 01:27 PM
zimmerj zimmerj is offline
If the residue is thick I used a hair dryer and rubbed it away with a finger. For the thinner stuff I used Meguiars polish (not wax) and it removed any evidence of the trim then I finished up with the spray on detail. I used the trim remover before but it had a chemical smell and the polish did the work the same so I went with the polish.
Old 02-02-2004, 02:56 PM
okie-chevy-man okie-chevy-man is offline
Banned
Send a message via MSN to okie-chevy-man Send a message via Yahoo to okie-chevy-man
Re: Re: Molding and emblem problem
This post is almost 2 months old. Isnt there a forum rule against reviving old threads?
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
07 Cabin Mildew/Mold problem Rodie40 Camry/Camry Hybrid/Vista 3 10-18-2009 12:10 PM
covering up badges and emblems nitr0x Graphic Manipulation 1 01-24-2004 10:40 PM
Molded-in emblem question... The Cougar Car Modeling 7 07-08-2002 07:00 AM
