Best engine swap?
What would be the best engine swap for my p4 gsr, around what price range and were would i find it.
thanks for helping |
whats wrongw/ the b18c1 in there?
y don'y u just use the money that you'd throw into a swap for mods instead example: high or low compression pistons depending on where you want to go w/ it, cams, cam gears etc.... thats what i would do you already have a pretty good engine |
c1 is a very competent motor...
but, wut are ur plans (all motor etc...)? that'll help us help u w/ advice...
2003 Infiniti G35 99 Yamaha YZF-R6 (sold) 2000 Acura Integra Type R (sold) 1994 Acura Integra GSR (retired/sold) |
My engine has 122,000 miles and before i plane on putting a rev hard stage 2 turbo i thought i should change the engine because of the high miles on the original one. Could this many miles be a reliability problem?
Re: Best engine swap?
It's a Honda engine, 122k is comparable to like 40k on a Dodge
![]() Get some low compression pistons if you're worried about reliability that much, and turbo the hell out of your c1. |
Start at 5 p.s.i. and make sure everything is working properly before adding more boost. If you don't perform the rebuild, you may damage the reciprocating components because of excessive heat or detonation, which will end up costing you more money. Good Luck. |
