Old 11-04-2003, 03:28 PM
GTPxtreme GTPxtreme is offline
GTP pulleys
Im a new owner of a 2000 GTP and want to put a new pulley in my car what pulley do you recommend? Or do you think I should start with other mods? Let me know what you think.
Old 11-04-2003, 03:53 PM
crashdummybip crashdummybip is offline
Send a message via AIM to crashdummybip
my buddy has a gtp and he picked up the 3" pulley from here. He liked the hp gains!! You will have to order a different belt also.
http://www.southfloridapulleyhq.com
They got other stuff there too.
Old 11-04-2003, 06:16 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Safest pulley for a stock car is the 3.4" pulley. Then go with a Cold Air Intake, and then Ubend delete and 3" down pipe.
I run a DUB Gen2 system and love it.
http://www.southfloridapulleyhq.com/...ucts_frame.htm
With a DUB type system you can change pulley sizes within 5min.
For a daily driver I run a 3.1" pulley, and at the track I can run a 2.9" pulley. I also have a 3.4 pulley that I use on long trips.
Mods:
Performance: CYA Racing PCM, Tranny #2 with 3.29 gearing, Thrasher Cam, Custom DHP PCM, 3" cutout, CYA Racing LSD, 3.4/3.1/2.9 DUB, MSP CAI & Catback & Desert Fox Tranny Cooler, Ported front Manifold, MDPP 3" Downpipe, no-ubend, shftkt(max), spring boosters, 160tstat, Mobil 1, Autolite 104, TB spacer & heat shield, Xover wrapped, ZZP wp & alt pulley, boost-tranny temp-volts, SNM motor mounts, Hurst line lockers
Old 11-05-2003, 11:31 AM
GTPpower GTPpower is offline
On my stock GTP, would that hurt my tranny if I put on a smaller pully. I have heard a lot about people that do very light mods, and then go through a few trannys. My car has 105,000 miles on it, and I don't have money to pay for a new tranny.
Old 11-05-2003, 12:34 PM
GTX Playa's Avatar
GTX Playa GTX Playa is offline
Send a message via Yahoo to GTX Playa
Next option
If you would like to baby step into smaller pulleys, SLP has one that is 3.5.
Old 11-05-2003, 04:15 PM
carnutcass's Avatar
carnutcass carnutcass is offline
I installed the Pulley Boys 3.4" on mine. The gains were quite noticable......although you would need some other mods on your car to feel the full effect. I don't know that I'd go any more aggressive than that with a 105,000 mile car. Just my opinion.
I'd get the cold air induction before I got the pulley.
Old 11-18-2003, 11:30 PM
rockford0384's Avatar
rockford0384 rockford0384 is offline
Re: GTP pulleys
yeah you can. I didnt start to do things to my car till i had over 130000 miles on it. and now it has 145000+ on it and still runs strong. I have a 3.4 pulley, cold air induction, u-bend cut out also with resisnator cut off with flowmaster 60 series delta mufflers, 16o degree drilled thermistat, 8mm wires. with autolite 104 platnium plugs, digital PCM WITHOUT a shift kit and its still shifts good. Come on, your all under-estamating the PRIX capabilaties
but yeah the shift kit is next on the list but miles dont matter when you take care of the car the right way.
